Secondly, there is a similar thread (which I've now 'lost') which it could have gone onto, but the advise on there was to change the chip - and i already have!!!!
So, to start at the beginning, it failed the MOT as the CO emmissions were too high (4.1%), no matter which setting the switcher chip was on.
The CO pot would adjust the number upwards, but it would go no lower (I didn't do it, the garage did!).
No flashing of the CEL has occurred.
My questions are thus:-
Can you adjust the CO level with the engine in 'normal' run mode, or does it have to be in 'flashy-engine-light-on-the-dash--no-sensors-connected' mode??? (shorting out the 2 wires on the aldl plug).
How can i get it lower?
Should i cheat and induce a slight air leak
I plugged elanscan into the car, and it shows 2 x MAT (low) faults - is this my problem??
I plugged the laptop in with the car stationary, and just up to 'fans kicking in' temp - should this have an effect on the readings?
CTS???
I took it for a run round the block and got full throttle for the last blast up the hill, so the elanscan file *should* have a reasonable set of conditions demonstrated, even though it's only a 1 mile trip.
Any answers greatly appreciated
PS - i don't have access to CO test kit at home, so any way of getting a rough indication??
