Elanbloke wrote:Gordon, that rheostat (I think it's actually a potentiometer - which is not that expensive say £17) may or may not be the problem but it works in conjuntion with a rheostat (which is expensive say £80+) that is plugged in near the indicator unit and some relays. On a RHD car they are up under the dash just by the drivers door and it's the green one. If you remove the pot you can test it with a meter to see if it's working. If it's not the problem there is a way to pull the rheostat and hot wire the circuit so you at least get dash lights. I have the info somewhere if you need it.
Enright13 wrote:It looks as though you don't even need to hack any wires - I think that you can bridge the terminals IPHC BI6 and IPCH BH7 in the connector block between the two components.
