Suspected Coil Failure
Postby Freelander » Tue 29.07.2008, 21:08
On the run to Silverstone, I noticed a drop in performance - to the extent that acceleration from low speed was difficult - similar to timing fault or fuel starvation. On the return journey, the performance deteriorated further although less noticeable at higher revs - obviously not fuel starvation. I checked the timing which was near enough. I suspected damaged spark plugs / leads / coils. Removing the plug leads in sequence, Plug 1 made no difference, plugs 2 & 3 caused a near stall and plug 4 made no difference. I now suspect that one of the coils has failed.
Have I missed anything or am I on the right track?
1990 SE Turbo - Silver - Work in Progress (Slowly)
'Go slow now - go fast later'
Freelander
Re: Suspected Coil Failure
Postby Specky » Tue 29.07.2008, 21:24
Freelander wrote:On the run to Silverstone, I noticed a drop in performance - to the extent that acceleration from low speed was difficult - similar to timing fault or fuel starvation. On the return journey, the performance deteriorated further although less noticeable at higher revs - obviously not fuel starvation. I checked the timing which was near enough. I suspected damaged spark plugs / leads / coils. Removing the plug leads in sequence, Plug 1 made no difference, plugs 2 & 3 caused a near stall and plug 4 made no difference. I now suspect that one of the coils has failed.
Sounds good... Just finish of your diagnosis... :wink: transpose the coils... should take 20-30 mins... and do the test again...
The fault should move...
Postby Freelander » Tue 29.07.2008, 22:15
Thanks for the heads-up. Could I simply swap over the coil-ends of the plug leads or must the coils be transposed on the baseplate? :?
Freelander
Postby Specky » Tue 29.07.2008, 22:41
Freelander wrote:Thanks for the heads-up. Could I simply swap over the coil-ends of the plug leads or must the coils be transposed on the baseplate? :?
Honest answer...
I don't know... :oops:
I'd play safe and swap them on the base plate...
