A piller seal tidying
Postby mikeydude » Wed 06.08.2008, 14:33
As mentioned in the past, I have been messing about with the idea of tidying the a piller seals...This is the result if anyone is interesed?
side window now slots into the rubber. It works well
It uses two pieces of rubber extrusion that is readily available and cheap. And is a much better looking solution to sikaflex or silicone
mikeydude
Postby Galsia » Wed 06.08.2008, 14:41
Galsia
Postby Gee0 » Wed 06.08.2008, 15:18
:bowdown:
Great Job, Looks like a good low cost solution.
A write up would be useful. ;-)
Gee0
Postby Sy V » Wed 06.08.2008, 15:50
Your ingenuity is to be applauded - well done.
LEC Godfather
Postby mikeydude » Wed 06.08.2008, 16:21
There is some way to go to perfect it as yet (in other words I am still messing with it) and I still want to see how strong the rubber is and how well it stands upto UV etc...not an easy test to do in the UK, perhaps I should take the elan to a sunbed centre!!
I am also putting together a remote fob that operates the windows from outside the car, this is so the window can be dropped and then lifted inside the rubber for a perfect weatherproof seal
One of the problems is all cars are slighly different so the mod will have to be applied carefully on an individual car basis.
I will do a write up when it's all done.
If people wanted I could put together a kit of the bits to make things easier.
mikeydude
Postby ailwyn » Wed 06.08.2008, 16:26
mikeydude wrote:If people wanted I could put together a kit of the bits to make things easier.
Well volunteered.
When your ready, kick off a new thread in the Group Buys section and I'll take spot no 1. ;)
ailwyn
Postby L.G. » Wed 06.08.2008, 20:07
Mike Dude,
Do you get any problems opening the door with the window up?
L.G.
'95 S2 driver #286
L.G.
Postby Doug » Thu 07.08.2008, 00:12
Nice purse, Mikey :wink:
Postby Gee0 » Thu 07.08.2008, 00:41
Is that what they call a MANBAG??????????????? :-D
Gee0
Postby tweetdriver63 » Thu 07.08.2008, 01:27
mikeydude wrote:There is some way to go to perfect it as yet (in other words I am still messing with it) and I still want to see how strong the rubber is and how well it stands upto UV etc...not an easy test to do in the UK, perhaps I should take the Elan to a sunbed centre!!
I just recently read somebody's posts (maybe Phil or Blair?) where they said they either were working on, or had installed, one of those bits that makes the windows automatically drop slightly when you open or close the door. You might try finding that, or maybe somebody else can chime in with more info on it for you. That would be better than manually doing it with a remote, eh?
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby mikeydude » Thu 07.08.2008, 13:48
Yes that would be good....ooohhhh just like a proper convertable....I was looking at that ldea but did not want to mess about too much inside the doors, this way I just have to put a readily availalbe remote reciever under the centre console and attach it to the switches.
mikeydude
Postby mikeydude » Thu 07.08.2008, 14:26
L.G. wrote:Mike Dude,
L.G.
Not it just flips out of the seal...very nice....
Its more difficult to get it back in with the window up!!
mikeydude
Postby mikeydude » Thu 07.08.2008, 14:27
Gee0 wrote:Is that what they call a MANBAG??????????????? :-D
Nope that's what's hanging on my stomach!
mikeydude
Postby mikeydude » Thu 07.08.2008, 14:28
Doug wrote:Nice purse, Mikey :wink:
Yes, I am trying to get in touch with my feminine side!
mikeydude
Postby GeoffSmith » Fri 08.08.2008, 14:39
tweetdriver63 wrote:I just recently read somebody's posts
Paul Watkins
Postby Elanlover » Fri 08.08.2008, 20:23
Yea, nice bling on your hands too.
That was you in the driver's seat............right? :wink:
Re:
Postby mikeydude » Thu 25.09.2008, 11:23
Paul Watkins
Thanks Geoff, I will take a look
mikeydude
