Interior fixtures: How to get hold of
Postby Andy_R » Tue 01.02.2005, 23:10
After making a couple of phone calls to Lotus parts dealers, I understand that some interior fixtures are no longer available.  Does anyone know where I could get hold of a couple of plastic interior door lever surrounds?<br><br>Andy
Andy_R
Re: Interior fixtures: How to get hold of
Postby Sy V » Wed 02.02.2005, 03:49
The elusive escutcheons.  A well known phrase about pitching equines and their faecal waste, springs to mind.<br><br>Breakers?
LEC Godfather
Postby Andy_R » Thu 03.02.2005, 00:02
Sy<br><br>What a marvellous word. I almost feel ashamed to have called them a plastic surround.<br><br>I did try one breaker, usually good at providing Elan bits - he almost laughted when I asked for them such is the frequency with which he's asked for the same part.<br><br>The phrase you refer to doesn't immediately come to mind, but I guess what you're saying is that I haven't got a horses sh*t chance of finding one. Is that about right?<br><br>Thanks all the same.<br><br>
Andy_R
Postby F1 LOTUS » Thu 03.02.2005, 02:18
Are you guys talking about these parts<br>Image<br><br>Somewhere I should have a mold for these...?
F1 LOTUS
Postby Doug » Thu 03.02.2005, 02:36
you the man, Brian!<br><br>If you have time to make some, I can transport them to buyers at Donington for you next month!<br><br>The B-post caps would be another sought after part!!
Postby F1 LOTUS » Thu 03.02.2005, 05:38
[quote author=AV8NDOC link=board=interior;num=1107295809;start=0#4 date=02/02/05 at 17:36:07]you the man, Brian!<br><br>If you have time to make some, I can transport them to buyers at Donington for you next month!<br><br>The B-post caps would be another sought after part!![/quote]<br><br> :oO-o-o-h sh1t!...I hope I can find the moulds (export spelling).
F1 LOTUS
Postby Andy_R » Thu 03.02.2005, 23:35
Brian<br><br>That is the part I'm looking for, but in standard material.
Andy_R
Postby F1 LOTUS » Fri 04.02.2005, 00:38
[quote author=Andy_R link=board=interior;num=1107295809;start=0#6 date=02/03/05 at 14:35:33]Brian<br><br>That is the part I'm looking for, but in standard material.[/quote]<br><br>You could probably sandblast one of these for texture then colour match with spray paint / vinyl?<br><br>Or...Use your existing parts to create a master pattern, pour a mold in high temp resin then vacuum-form your own parts? I'm sure you could find plenty of reference on the web from the modelling guys on how best to do this???<br>
F1 LOTUS
Postby nitroman » Fri 04.02.2005, 02:52
There is a Ford flexible interior paint (I use the one they sell in a spray bottle) I have used in the past.  You cannot tell it from original.  Tomorrow I will look at the can in the storage room & get the part number off of it.  You can buy it from any Ford dealer.
nitroman
Postby Jeff » Fri 04.02.2005, 03:55
Could that be applied to the cf bits that Darren is doing?
Jeff
Postby Darren » Fri 04.02.2005, 13:11
[quote author=Jeff link=board=interior;num=1107295809;start=0#9 date=02/03/05 at 18:55:03]Could that be applied to the cf bits that Darren is doing?[/quote]<br><br>I'm sure I can ask for none lacquered versions if you're planning to repaint them.<br><br>That said, the mark III versions of these parts are going to contain more resin, so hopefully surface airbubbles should be a thing of the past, thus removing/reducing the need for lacquer.<br><br>Darren<br>~~~~~<br>
Open mouth, insert foot.
Darren
Postby nitroman » Fri 04.02.2005, 19:15
The Ford paint is "Automotive Interior Spray Lacquer" M4J-4201-H, dark titanium interior.  It is a 13oz spray bottle.  It is very tough stuff & I have never scratched, worn or marred it.
nitroman
Postby F1 LOTUS » Sun 20.02.2005, 19:10
[quote author=Brian_MDB link=board=interior;num=1107295809;start=0#3 date=02/02/05 at 17:18:20]Are you guys talking about these parts<br>Image<br><br>Somewhere I should have a mold for these...?[/quote]<br><br>Eureka!<br>The mold and master pattern have been unearthed so it should be possible to supply new parts, I'm working with Darren on this and for the 'B' Pillar Caps so he can offer a full kit of parts...
F1 LOTUS
Postby nitroman » Sun 20.02.2005, 20:02
I have a spare both RH & LH side in excellent condition.  They came with the car when I bought it but were never used.  The guy's son was trying to replace all the broken plastic bits and got these too for whatever reason.  Don't know what they are worth.  Perhaps someone can advise.  Would this be a good item for EBAY then?  (as I am losing my ass doing these bolt kits!)  ;D
nitroman
Postby Sy V » Sun 20.02.2005, 21:29
No, they would be a good item to sell to  me direct.<br><br> ;D
LEC Godfather
Postby stevieshag » Sun 20.02.2005, 21:31
Well i sure would like a pair even in CF or not... as both of mine are chipped...<br>
black lotus elan se (kermit)
Mitsibushi outlander
suzuki gsx 750 W (Gonzo)
stevieshag
Postby nitroman » Mon 21.02.2005, 00:11
Upon inspection the LH escutcheon ON MY CAR has a crack in it so I'll have to keep that spare.  I can part with the RH one though.
nitroman
Postby Readit » Fri 17.06.2005, 22:23
Cant help with replacement parts but may save some other breakages. One of mine was broken and I puchased a whole car for parts ( not just for that bit!!!). But when I went to remove the replacements I found that the fixing screws had been overtightened and pulled through  so some 'lotus' fitter had Sikaflexed them on at the back. Trying to remove them with a screwdriver at the edge would have resulted in a similar breakage. A thin pallet knife inserted carefully to cut through the sikaflex gives a good result. To all future 'lotus' fitters reading this---- sikaflex a washer to the back of the broken hole to support the original screw ---better idea
All the best plans are flexible, Lotus use Sicaflex.
Readit
Postby TheBard » Sun 21.08.2005, 20:44
Is there any update on the CF escutcheons?
Cos I'd be interested to know the price for a pair, as I'll be buggering up my doors fitting new speakers soon :lol:
And before anyone asks, yes I've already got my spare orange clips! 8)
Ian
TheBard
Return to Interior
