F1 Lotus wrote:bobbrown wrote:... the Wilwood 120-6806 os the same as the 120-6816 but with smaller postons ...
The correct caliper part # is 120-6806. Please change Wiki
(I chose mine and Doug's piston size based on the AP kit)
Somewhere [don't know when] the part number got mis-quoted. ...it's difficult to know exactly how many people might have bought the '6816' caliper in error? Sorry
OK, I have changed the reference number in the WikiLEC article to show 120-6806 and referenced F1Lotus's comments on this thread.
However I'm not happy the explanation is as simple as a typo in Geoff's 16" Wilwood upgrade write-up on the Wiki, and in Elanman Gareth's thread on a repeat 16" order. Before everybody with 16" kits panics, I think we need some info from ESM and Monty.
As Brian says, Monty has used the 6816 Wilwood kit hard on track and can provide empirical evidence. Since both the 16" Wilwood upgrade thread and the later 15" upgrade thread have disappeared from the LEC site without trace, there is no way of checking caliper specs that way. Therefore any contemporary information from F1Lotus or ESM is the best we can hope for. {edited to say I thought ESM put the original 16" UK kit together, however he did not, as corrected by F1 lotus below}.
I have saved much information on the 15" upgrade, since that is what I have, but nothing on the 16". However I think Monty is right that everybody with the 16" kit bought the 6816 caliper. The only piece of evidence I have for that is a question of mine to ESM in Sep 2005 about rear brake upgrades where I ask:
In the rear-brake discussion were you referring to the 16" brake upgrade as the one using dynalites (as you quote a 44.5mm pot, and are replying to a USA member who has 16" wheels)?
Now, this implies that ESM quoted a 44.5 mm pot for a front Wilwood caliper. The Wilwood caliper with that pot size is the 6816. This implies that the 6816 was the caliper used in the 16" upgrade kit from May 2005. The fact that all other surviving threads refer to 6816 and none refer to 6806 also points to the 6816 being specified.
If Brian or Alan can find any contemporary supporting information, that might settle things.
PS: for reference, the 15" kit uses four-pot Powerlite calipers (120-8729) which hav 35.1mm pots, however no dust seals (as there is no room behind a 15" wheel to fit a dust-sealed caliper like the Dynalite).
The 16" kit uses Dynalite calipers which do (I think) have dust seals. As shown in the Wilwood URL referenced, the only difference between the 6806 and the 6816 is the size of the pistons (6806 = 35.1mm; 6816 = 44.5mm); accepted disc widths are the same.
As the 16" kit also uses a larger diameter disc than the 15", even the smaller pot 6806's should provide greater braking force than the 15" kit.
I have the 15" kit and think the braking is very good; furthermore the pedal travel is small and rock-solid - no complaints.
sake
Only kidding
