LGM Turbo Group Buy - Start Shipping Out Yeah
Postby dapinky » Tue 19.08.2008, 17:46
Can i have first shout on the 500 rounds of belt feed 7.62mm on the right? :smt067
Postby CRAMBURY RS » Tue 19.08.2008, 18:48
dapinky wrote:Can i have first shout on the 500 rounds of belt feed 7.62mm on the right? :smt067
those are probably Marie's :wink: you don't want to be on her bad sad...she pop a cap in dat azz!!!
hey Ekkers, do you have a name for every one of those downpipes? not that i need them, just wondering if there will be a spare?
CRAMBURY RS
Postby Ekapol » Tue 19.08.2008, 19:11
CRAMBURY RS wrote:hey Ekkers, do you have a name for every one of those downpipes? not that i need them, just wondering if there will be a spare?
All downpipes have names on them. I'm sure if you ask her nicely she'll make you an extra but that means another trip to the place where we got them... quite a drive there. :-)
Yep. Marie's stuff.
CRAMBURY RS wrote:
also in the center...a tasteless sofa! :lol:
Umm...I wouldn't make those comments :smt066 ;-)
Ekapol
Postby abmunro » Tue 19.08.2008, 20:43
Exhaust Manifolds
1. Aiwyn
2. Dico
3. Richard K...
4. MattRI
5. Marie
6. Ekapol
7. A B Munro
abmunro
Postby lotusgirlmarie » Wed 20.08.2008, 06:00
those are probably Marie's you don't want to be on her bad sad...she pop a cap in dat azz!!!
Ummmmm................. in a word, No. Only paintball stuff in those cases. Mostly for my custom pistol and rifle
The couch is summery.. Rather quaint in the right setting like my old sunroom. Deffo not to good with a clear plastic tarpon it covered in car parts.
My custom made Tiberius Tag 8 pistol
lotusgirlmarie
Goddess
Postby dapinky » Wed 20.08.2008, 15:58
Totally :offtopic: , but what sort of accurate range do you get on the Tiberius?
I've got a modded Glock 17 which is pretty good up to about 25m, then the accuracy goes a bit low :(
It can still be painfull at twice that distance (i've had the bruises to prove it), but probably less so than the un-modded one :D
Postby lotusgirlmarie » Wed 20.08.2008, 17:33
My Tag is pretty accurate out to 30M. After that it wanders out to 6-8". Again, though, its only a paintball marker. Granted it was originally designed for law enforcement 8)
Back on topic. When I get back to SF tonigh I'm going to try and get a few more downpipes mocked up. Sould be a productive couple of days off.
lotusgirlmarie
Goddess
Postby lotusgirlmarie » Fri 22.08.2008, 04:04
heya boyz,
Just a quick update. All of the downpipes are mocked up and tack welded togeather. I just need to finish port matching the inlets then they can be sent out for gas sealing and jet hot coating.
lotusgirlmarie
Goddess
Postby CRAMBURY RS » Fri 22.08.2008, 22:42
lotusgirlmarie wrote:heya boyz,
yep, it's official...you're FVCKING AWESOME!!! :wink:
CRAMBURY RS
Re: LGM Turbo Group Buy - Deadline July 5th
Postby lotusgirlmarie » Fri 29.08.2008, 10:20
well boyz, made some more progress today. The photo shows four of the five compressor housings in varous stages of grinding, sanding and polishing. Alot of work to get them to look good. As they sit now 3 of the five are ready for buffing and the other two are nearly so. I'll be heading down to the welders check up on the downpipes and BOV's later today before my trip.
lotusgirlmarie
Goddess
Postby abmunro » Sun 31.08.2008, 21:46
Hello Marie
My pal is asking me which turbo we are getting.
Is it
GT2560R - 707160 - 9
GT2560R - 466541- 4
GT2560R - 466541 - 1
Tony
abmunro
Postby CRAMBURY RS » Mon 01.09.2008, 03:56
abmunro wrote:Hello Marie
Is it
GT2560R - 466541- 4
Tony
i thought it was the 466541-1, which is identical to the -1 except for the material of the wheels. the 707160-9 is actually a GT2860R, not a GT2560R. i just got the -4 last week, waiting for it in the mail.
i need to see about a downpipe though...coughmariecough :poke:
CRAMBURY RS
Postby abmunro » Mon 01.09.2008, 08:22
Got this info from the link below
Turbo's by Garrett
Medium Frame
GT25-GT35
A huge selection of journal bearing turbos, housing options, and our proven patented ball-bearing turbos. Wastegated or free-floating; from the quick-spooling GT2554R to the competition-crushing GT3582R, you'll find your best options here whether you want 170 hp or 550 hp.
GT25
GT2554R - 471171-3
GT2560R - 466541-1
GT2560R - 466541-4
GT2560R - 707160-9
GT28
GT2854R - 471171-9
GT2860R - 707160-5
GT2860R - 707160-7
GT2860RS - 739548-1
GT2871R - 472560-15
GT2871R - 743347-1
GT2871R - 707160-10
GT2871R - 743347-2
GT2871R - 771847-1
GT2876R - 705330-1
GT2876R - 705330-2
GT30
GT3071R
GT3071R - 700382-3
GT3071R - 700382-20
GT3076R - 700382-12
GT32
GT3267 - 452233-5
GT3267 - 452234-2
GT3271 - 452203-1
GT35
GT3571 - 731413-1
GT3582R - 714568-3
GT3582R - 714568-1
GT3582R - 714568-2
Turbo Comparison Sheet
abmunro
Postby CRAMBURY RS » Tue 02.09.2008, 03:33
abmunro wrote:Got this info from the link below
Turbo's by Garrett
GT2554R - 471171-3
GT2560R - 466541-1
GT2560R - 466541-4
GT2560R - 707160-9
the first is OUT unless someone specifically asked for it. while the GT2554R is lightening fast in spool it doesn't make the top end that the 2560's do, the second and third seem to have the broadest map as they are essentially the same unit minus material used for the wheels, and the last is GT-R specific.
CRAMBURY RS
Postby lotusgirlmarie » Tue 02.09.2008, 07:06
466541-0001
GT2560R
Thats what it says on the tag and on the frame.
lotusgirlmarie
Goddess
Postby CRAMBURY RS » Tue 02.09.2008, 07:28
lotusgirlmarie wrote:466541-0001
GT2560R
that's what i figured...i was starting to doubt myself for a second :? welcome back to the ground.
btw, do you have more install pics of your setup? i was hoping to gather some more information before my build. thanks, cram :)
CRAMBURY RS
Postby abmunro » Tue 02.09.2008, 09:13
Thanks for confirmation :-D
abmunro
Postby abmunro » Tue 02.09.2008, 09:26
abmunro
Postby CRAMBURY RS » Thu 04.09.2008, 08:50
that was actually some good reading.
btw, got my GT2560R and DAMN that thing is big compared to the IHI, even compared to the Tbird (though not much bigger than stock). i know LGM posted pics, but until you have it in your hands you just don't realize it. you boys are gonna be STOKED!!!
hey Marie, i know you don't have parts to make an extra DP, but if you have some scraps, is a heatshield out of the question??? cheers
CRAMBURY RS
Postby CRAMBURY RS » Sat 06.09.2008, 07:25
holy crap all you boys are lucky to have Marie doing this for yall, because i have to tell...just clocking the damn CHRA and getting fittings in is fun enough.
btw, i think you all have more room between the radiator and manifold. i had to shave the bracket under the wastegate actuator.
here is a pic, not as shiney as yours but still works. i'm starting to appreciate LGM's custom downpipes more now that i realized how much room there is to work with.
like i said, you're all luck to have Marie...and Ekapol :-D
CRAMBURY RS
