Warm Start ?
Warm Start ?
Postby Avonvilla » Wed 13.08.2008, 15:36
My Elans always been harder to start warm than cold or hot, starts on the button when hot or cold but when warm can take a few seconds of turning over. Is this normal or if not what should i look at ?
Avonvilla
Postby Sy V » Wed 13.08.2008, 15:45
Yeah, we've done this one before with an inconclusive outcome.
Whether it's normal is open to debate, but it's certainly common.
LEC Godfather
Postby tweetdriver63 » Wed 13.08.2008, 16:06
I have the same problem. It's a bit embarrassing sometimes. I had some hope that new coils would help, but I've now replaced the coils, leads, and plugs, and I don't see a change (at least not where the starting is concerned).
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby Avonvilla » Thu 14.08.2008, 18:50
Ok i'll forget it then lol, cheers.
Avonvilla
Postby Doug » Thu 14.08.2008, 19:20
not that Elans get any true vapor lock, but are we allowing the fuel pump to fully pressurize before starting in these instances? if not try it and see if it helps :?
Postby Avonvilla » Fri 15.08.2008, 01:18
Doug wrote:not that Elans get any true vapor lock, but are we allowing the fuel pump to fully pressurize before starting in these instances? if not try it and see if it helps :?
tried that no differance :(
Avonvilla
Postby tweetdriver63 » Fri 15.08.2008, 02:43
Me too. :smt022
'91 Elan SE
tweetdriver63
Postby Markinstance » Wed 20.08.2008, 17:48
I get the same. I even took the car to the rolling road to see if they could identify the problem, they told me that the Coolant Temp Sensor was the problem. I changed this and still have the same problem.
The car starts on the button when its cold and hot and is a real pig when warm. When it does start its very rich and smells of petrol. About the only thing I have not tried is new coils.
May car can take 10 - 20 seconds of cranking before it starts. It does start all the time (touch wood) but does take ages to finally fire.
I also let the fuel pump prime.
Mark
Markinstance
Postby tweetdriver63 » Wed 20.08.2008, 17:56
Mark, same exact thing with mine. I just replaced the plugs, leads, and coils, and got no improvement....maybe a bit better performance, but no improvement in the starting problem.
'91 Elan SE
tweetdriver63
Postby Avonvilla » Wed 20.08.2008, 23:43
I feel blessed now as it's only 4 or 5 seconds of turning over on warm with mine !
Avonvilla
Postby Rambo » Thu 21.08.2008, 09:24
I also get this - starts on the button when cold and hot but takes 4-5 seconds of cranking when warm - but not all the time :? I've heard of quite a few others with the same problems over the years.
However, in the 5 years of ownership it has never failed to start (apart from when my alternator packed in) so doesn't really bother me.
Postby surfboardfiller » Thu 21.08.2008, 14:12
I have this problem with a 4 Elans. My immediate guess was the ECU not mixing the fuel so well for a warm start.
surfboardfiller
Re: Warm Start ?
Postby DeanG » Wed 03.09.2008, 23:30
I do not have that problem, however when I had a diagnosis at Symbolic in CA a few years ago they said that an injector was weaping and that could cause hot start problems.
DeanG
