Doug wrote:I'll guarantee you that you can use ElanScan to make a "prom dump" to a file, and ESM can tell you exactly what chip is in your car from that file.
You could have a chip already or you could have an inaccurate gauge on the dash. ElanScan can also tell you the true boost the engine sensor (different from the dash gauge) is seeing to see if it is truly increased or not.
It's worth checking for a manual boost controller as well Chris.John_W wrote:I don't mean to imply that any of the above were the cause of Doc's disappointment, as I'm sure he's been around Elans long enough to know what to check to optimise performance, but I wanted to add to Brian's comments.
GeoffSmith wrote:Doug wrote:I'll guarantee you that you can use ElanScan to make a "prom dump" to a file, and ESM can tell you exactly what chip is in your car from that file.
