by trooper762 » Sat 06.09.2008, 16:56
Hi All, OK I've had My Elan SE now for a while but the Wife gets the pleasure of Driving it as I'm blessed with a very Tax Heavy and boring company car.
Anyway, she reported to me last night that for some time (Why do they always leave it too long to tell you?) that the foot wells feel rather warm and also that the engine light comes on every now and then.
I've done the paper clip test and it reports an error 41 "CAS error".
Is this also the reason for the increased temp in the foot wells? Also, where can I go In Leeds / West Yorks area to get the CAS changed (Without breaking the bank)
Any help will be more than welcome.
Cheers Lee
trooper762
by tweetdriver63 » Sat 06.09.2008, 17:52
If you click the "Repairs" link above, you'll find the CAS listed under common repairs. There's a write-up there. It looks a pretty easy DIY job. You shouldn't need to feed somebody else's piggy bank on this.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
by jcab » Sun 07.09.2008, 07:53
My car had a code 41 fault, which was the Hall Effect Sensor within the CAS. After ordering a new Sensor, and they are only £20 from Lotus Aftersales, I had nothing to lose and decided to try a repair.
The soldered joints within the Hall Sensor seem to be the problem and I carefully cut and peeled back the silicone sealer from the back of the sensor and exposed the contacts. Take it very slowly and it's not difficult. There are no moving parts in the unit, just these soldered connection, which were resoldered. I then resiliconed the back of the sensor.
It all worked Ok for me, and when the Dealer failed to send a replacement Sensor, I had a repair that cost nothing.
It's worth noting that the new type of sensor has different connectors to the wiring that will need modifications. Also, I did mine with the CAS on the car, but having taken it off more recently to replace the O ring seal, this would be much easier way to repair the Hall sensor. Either way you should recheck your base timing.
I have a couple of photos of the repair - just let me know if you need them.
jcab
by Dave Eds » Sun 07.09.2008, 08:02
jcab wrote:I have a couple of photos of the repair - just let me know if you need them.
Could you please add them to the wiki write up so we all can share!
Thanks.
by jcab » Sun 07.09.2008, 10:59
I'm struggling with the Wiki, which keep asking for my login even though I'm logged in to the LEC.
I have drafted some text and added a photo of the repair to the Hall Effect Sensor - if it is of any use, please could someone upload it to the Wiki?
- Attachments
Lotus Elan Hall Sender.doc
- (890.5 KiB) Downloaded 247 times
jcab
by Dico » Sun 07.09.2008, 12:29
Chris Foulds - Lotus specialist (with knowledge of the Elan) is based near you.
- Fool Boy Four - Founder
by Galsia » Sun 07.09.2008, 14:47
Galsia on Thu 06.05.2010, 16:30, edited 1 time in total.
Galsia
by al » Sun 07.09.2008, 18:24
jcab wrote:I'm struggling with the Wiki, which keep asking for my login even though I'm logged in to the LEC.
[Currently] you need to create yourself an account on the wiki as well as the one here. Give that a go
al
- LEC Bit Basher
by trooper762 » Tue 09.09.2008, 01:07
so the temp gauge does get to about midway in traffic I souldn't be worrying about a sticky thermostat then?
trooper762
by Specky » Tue 09.09.2008, 08:07
trooper762 wrote:so the temp gauge does get to about midway in traffic I souldn't be worrying about a sticky thermostat then?
It'll go to 3/4ish and then the fans should kick in....
Then drop to about 1/2.. Then the cycle begins again...
