by Specky » Tue 23.09.2008, 14:45
I'm looking for a Nut Splitter or 3...
It's gotta be robust and be able to used time after time
and go up to 20mm- ish
Has anyone got any reccomendations...
by RayD » Tue 23.09.2008, 15:07
I've never used one Dave, but if you must, I’d go for the best one available with a warranty attached to it...It looks as though
Snap-On do one.
Ray
RayD
- Forum Member
by Sy V » Tue 23.09.2008, 15:31
12-16mm and 16-22mm
here.But I get accused of favouring this site. My reasoning is that their speciality is classic car restoration which makes them the SMEs to me.
- LEC Godfather
by Specky » Tue 23.09.2008, 15:59
Do you reckon they would remove the :-
Outb'd seat mounting nuts...
Turbo/manifold nuts
by Specky » Tue 23.09.2008, 17:43
by Sy V » Wed 24.09.2008, 08:30
FKs... never had to use one mate.
- LEC Godfather
by DeeAitch » Wed 24.09.2008, 09:13
I've used one a few times in the past - they do work but are a pain as it is very difficult to get them to locate right up to the face of the nut, impossible if the nut has an integral flange. Access is never good - that angled one looks to be an improvement on the straight ones I have.
Most times I've only managed to fully split the nut if it has first backed of a few threads. Usually it only partially splits the nut but that can be enough to get it off if all else has failed.
DeeAitch
by ailwyn » Wed 24.09.2008, 09:16
Dave,
I've used one like the Frost offering, however the problem you'll get with the turbo/(exhaust?)manifold is clearance, there's not much room there... An alternative for these is to remove the whole turbo/manifold as one piece then use the block mountings on the manifold to secure the lot to a flat surface (I used a diy workbench and G clamps), then heat the manifold which should free up the stud for removal from the manifold...this assumes that you've not already rounded the securing nuts.
Ailwyn
ailwyn
- Forum Member
by Monty » Wed 24.09.2008, 11:04
Specky wrote:Do you reckon they would remove the :-
Turbo/manifold nuts
Can you not grind off the O/B seat bolt?
- Chunder King!
by Specky » Thu 16.10.2008, 17:54
Nope.. The splitter leaked grease upon the first time of using....
Not HP...
by BFG in the BRG » Fri 27.03.2009, 23:26
I've use one - they're pretty good, but like DeAitch said - providing you van get the splitter on properly - Dremmels are pretty good to - just need to be mindful of the heatbuild-up.
Alas soon to be Elan-less
BFG in the BRG
Return to Tools
