seamus wrote:I am thinking of selling my 1990 elan se because on the mot it had an advice note that the suspension had heavy surface rust.
I guess this means the wishbones need replacing.
they are priced at 350 each.
Does anyone know where to get them sandblasted and recoated.
Or is there any other solution?
When the cars worth 3500 to 4000 I am not going to spend 2x350 pounds.
mnemonix wrote:I've just done mine in Hammerite and they should be good for years now.
Chris.
Paul.P wrote:mnemonix wrote:I've just done mine in Hammerite and they should be good for years now.
Chris.
Chris, unless you've got a different Hammerite to me & Monty, it won't last the winter, i assure you, Dico got some good rust preventative stuff, he's away till next week, but might be worth asking him when he's back, or actually i think Monty has just done his again with a different product.
...seamus wrote:I am thinking of selling my 1990 elan se because on the mot it had an advice note that the suspension had heavy surface rust.
Monty wrote:If they`d said that there wishbone have heavy rust then i`d say there ready for the bin, try hitting the underside off the wishbone with a flat end screwdriver to see if it will punch a hole. I`ve had a rear wishbone go and it went at the weld and put the wheel in to the bumper![]()
If they seem solid your better off removing them to clean and treat with some kind off rust killer then apply Dinitrol or POR15 or Waxoyl.
BTW it`s not exactly a Major project
Monty wrote:...BTW it`s not exactly a Major project
