Sy V wrote:Monty wrote:...BTW it`s not exactly a Major project
Steady on Jay; it might not be a daunting task to a spanner like you
ailwyn wrote:Sy V wrote:Monty wrote:...BTW it`s not exactly a Major project
If you think the mods are wide you should see the admins (eh Specky?)
Shrek wrote:I've been misquoted...
Bolsom wrote:I am about to clean my front wishbones etc. They appear to be solid but have a good coating of rust.
I was thinking of cleaning them with a wire brush on a drill with handwork on the hard to get at places.
I was wondering if using hammerite paint (several coats) would work. It would hopefully last longer
than waxoil if it didn't chip off. Does anyone have experience/comments on this please.
Colin
John_W wrote:Bolsom,
I use Hammerite and Waxoyl, however it doesn't last longer than a year or so. This winter I'll try por15 (http://www.por15.com/) & Bilt-Hamber (http://www.bilthamber.com/corrosionprevention.html) instead.
Have a look at these threads:
viewtopic.php?f=79&t=13794&p=178593&hilit=por15#p178593
viewtopic.php?f=41&t=7512&p=85370&hilit=por15#p85370
viewtopic.php?f=80&t=6181&p=69806#p69806
bobbrown wrote:I doubt it was the sand blasting that made the hole it was probably already rusted to the extent that when it was sand blasted it just revealed the hole or the lack of metal.
theelanman wrote:in theory you shouldnt galv after its been welded up.....
once in the hot bath the air will expand and not only distort your bone but maay possibly 'blow' it......usually goes bang and splits the weakest point....
bobbrown wrote:With hollow sections they have to have vent holes drilled if they are hot dip galvanised, you have to complete the welding before it is hot dipped! Distortion may occur but this is due to heat rather than air expansion.
)......theelanman wrote:Ive nere seen a wishbone with holes in (that were supposed to be there....)......
ailwyn wrote:theelanman wrote:Ive nere seen a wishbone with holes in (that were supposed to be there....)......
Pretty sure my S2 bones have drain holes in them
Mine definitely have.GeoffSmith wrote:ailwyn wrote:theelanman wrote:Ive nere seen a wishbone with holes in (that were supposed to be there....)......
