Hi-Spec rear conversion
Postby bobbrown » Mon 10.11.2008, 11:49
A list for those who are going to commit to the rear conversion so I can get the best price out of Hi-spec
1. bobbrown
Pacific Blue N/A
bobbrown
Re: Hi-Spec rear conversion
Postby ailwyn » Mon 10.11.2008, 12:20
1. bobbrown
2. Ailwyn - Going for BB Hi-Spec Fronts
3. Ailwyn (just the not-off-the-shelf bits) - Going for BB Hi-Spec Fronts
ailwyn
Postby Monty » Mon 10.11.2008, 13:34
Bob,
I`m going to leave my name of the list for the calipers for now as i`m skint, but i do understand that this maybe the only opportunity to get a good discount from Hi-spec so depending on the price i may have to get the credit card out again :roll:
Postby paulwatkins » Mon 10.11.2008, 14:20
1. bobbrown
4. PaulW
paulwatkins
Postby Elanlover » Mon 10.11.2008, 14:49
1. bobbrown
4. PaulW
5. Elanlover
Bob, would it help if HiSpec were also aware that some of us were planning on buying front calipers (and maybe their whole kit) as well? It might encourage them more to know that there's also some front calipers to be sold IF they make the rears for us. Could make another list for the fronts too.
Postby bobbrown » Mon 10.11.2008, 14:54
I have taken this into account and will be used when I come to get a price
Pacific Blue N/A
bobbrown
Postby surfboardfiller » Mon 10.11.2008, 21:18
1. bobbrown
4. PaulW
5. Elanlover
6. SuferPhil - Not sure yet, probably AP up front for the track car with the adjustable bias and 16" S2 wheels
surfboardfiller
Postby Nige » Mon 10.11.2008, 21:32
1. bobbrown
4. PaulW
5. Elanlover
7. Nige (Already got the fronts).
Back in Blighty
Nige
Postby nitroman » Mon 10.11.2008, 21:54
1. bobbrown
4. PaulW
5. Elanlover
8. Nitroman - Wilwood 6811 front
nitroman
Postby Fubar1764 » Tue 11.11.2008, 07:17
1. bobbrown
4. PaulW
5. Elanlover
9. Fubar1764 - Wilwood 6811 front
-Your "Jack" of all trades
Fubar1764
Postby G UK » Tue 11.11.2008, 10:06
1. bobbrown
4. PaulW
5. Elanlover
10. G UK
https://gridcoin.ddns.net
G UK
Postby RichardK » Tue 11.11.2008, 13:39
1. bobbrown
4. PaulW
5. Elanlover
10. G UK
11. Richard K - HiSpec under 15" rim already fitted
RichardK
Postby ailwyn » Tue 11.11.2008, 13:47
Can everyone please add on their front brake setup. Bob has already said that he won't supply upgraded rears unless your fronts are suitably upgraded.
Ailwyn
ailwyn
Postby G UK » Tue 11.11.2008, 14:58
1. bobbrown
4. PaulW
5. Elanlover
10. G UK - Hi-Spec 16" Fronts already fitted
G UK
Postby bobbrown » Tue 11.11.2008, 15:35
1. bobbrown
2. Ailwyn - Going for BB Hi-Spec Fronts 16" 294mm x 24mm front 256mm x 24 rear
3. Ailwyn (just the not-off-the-shelf bits) - Going for BB Hi-Spec Fronts 16" 294mm x 24mm front 256mm x 24 rear
4. PaulW
5. Elanlover
8. Nitroman - Wilwood 6811 front willwood rear disc 298mm x 20.6mm 2 piece
9. Fubar1764 - Wilwood 6811 front willwood rear disc 298mm x 20.6mm 2piece
10. G UK - Hi-Spec 16" Fronts already fitted 240mm x20mm diameter rear
11. Richard K - HiSpec under 15" rim already fitted 240mm x 20mm diameter rear
12.
Disc sizes calculated to get close to 70:30 split and not allowing the braking to become rear biased
Pacific Blue N/A
bobbrown
Postby abmunro » Tue 11.11.2008, 18:29
1. bobbrown
4. PaulW
5. Elanlover
7. Nige (Already got the fronts 300x28mm Front Discs - Hi Spec Billet 4 Calipers).
12. A B Munro - A P Racing front discs and calipers
abmunro
Postby Dico » Wed 12.11.2008, 23:47
1. bobbrown
4. PaulW
5. Elanlover
13. Dico - currently have Wilwoods 16" kit up front, wanting to upgrade to BB's front Hi'spec 16" kit.
Postby Elanlover » Thu 13.11.2008, 14:15
1. bobbrown
4. PaulW
5. Elanlover (custom HiSpec front set up as per Bob's specs)
Postby bobbrown » Fri 14.11.2008, 12:44
I have spoken to Hi-Spec and have a price out of them
Rear calipers are £280.00 inc vat pair (normal price £364.00)
Fronts are £280.00 inc vat a pair (normal price 366.6) economy calipers silver only £216.00 (normal price 286.7)
Note prices are axle set!
These have to be ordered on the one order to get this price. Current cost for people in the list stands at £4240.00
There will be a left rear and a right rear much as the current setup is so the handbrake cable follows the same route as current setup does.
Colour choice is down to the individual so standard colours are Black, silver, and gold, but other options are available like red.
I will need to know individual choices with regards to colour and if you want to source the discs or want a complete kit ready to bolt on.
I can then give you each an individually price according to how much or how little you wish to buy.
Please either PM or email the details across (Robert at swcsl dot co dot uk)
Bob
Pacific Blue N/A
bobbrown
Postby Monty » Fri 14.11.2008, 15:06
At that price i`m in for the rear calipers :-D
1. bobbrown
4. PaulW
14. Monty - BB`s 16" wilwoods front fitted.
