Samco silicone coolant hoses, possible group buy.
Re: Samco silicone coolant hoses, possible group buy.
Postby james@amber » Mon 24.11.2008, 17:14
try now :oops:
james@amber
Postby GeoffSmith » Mon 24.11.2008, 17:23
Picture: :smt023
Moulding: :( I'm afraid I won't be buying a set unless you can get them without.
Postby james@amber » Mon 24.11.2008, 17:36
thay are not going to do it without.
the only other option is the normal black, whick will have a white logo on, and then get out the white spirit !
cheers
james
james@amber
Postby nitroman » Mon 24.11.2008, 17:40
james@amber wrote:thay are not going to do it without.
cheers
james
Geoff, didn't you mention your pantry was stuffed to overflowing with Bacardi 151?
nitroman
Postby GeoffSmith » Mon 24.11.2008, 17:42
cheers
james
Yes Matt, but that's Sarahs!
Postby Elanlover » Mon 24.11.2008, 19:02
That logo looks like its "cut out" of the hose so to speak. Should I be nervous that the hoe would be weakened there and possibly spring a leak????
Postby nitroman » Mon 24.11.2008, 19:37
Elanlover wrote:That logo looks like its "cut out" of the hose so to speak. Should I be nervous that the hoe would be weakened there and possibly spring a leak????
Blair, I think it's more of a 'brand' (impression; think cattle) whilst the hose is still hot. I only don't like it because when you are cleaning your rag & dirt get caught in it. Think I'll just take the 'alcohol' route. Geoff, pass the 151.
nitroman
Postby Elanlover » Mon 24.11.2008, 19:43
I'm sure you're right and I doubt Samco would make something that didn't stand up to normal useage. Still, I can't help think that if there ever was a pressure failure and leak it would be in that stamp where it would occur. That's just the paranoia speaking out though :smt119
Separated by a common language
Postby tigerdog » Mon 24.11.2008, 20:23
Does British "white spirit" = US "ethanol" / "ethyl alcohol" / 190 proof booze? I thought it was a petroleum-based solvent of some sort. At any rate, what is the safest way of removing Samco's white marking?
Postby GeoffSmith » Mon 24.11.2008, 22:28
Stoddard solvent? The safest way of removing Samco's white marking would obviously be at source (i.e. don't print it), but it would appear that the customer is never right in Samco's view, so this potential customer isn't buying as my S2 hoses are just fine. Please feel free to convey my displeasure James and sorry you're not getting a sale in these financially challenging times.
Postby Specky » Mon 24.11.2008, 22:46
My evil side says MEK that'll remove the print... :twisted:
Postby james@amber » Wed 26.11.2008, 18:49
to be totally honest i dont much like the new "classic black" myself, but hey i dont make the colours, i just sell what they have !!
i have got a sample from samco with a logo, and you can quite easliy scrub the white logo off, and leave the feintist of black logos on the black hose.
thats the best way we are goint to get round the issue of having nice shiny hoses with little or no logo showing.
i will try and post a pic of my efforts tommorrow.
cheers
james
james@amber
Postby muley » Wed 26.11.2008, 22:41
James
Brace yourself! I'm going to place an order soon - just hmming and haaing over which colour. Happy to have the logo and 15% VAT ;)
Muley
Postby james@amber » Thu 27.11.2008, 12:26
this is the hose with one of the logos taken off
you can just about see where the samco wording used to be.
cheers
james
james@amber
Postby Elanlover » Thu 27.11.2008, 14:08
What did you use to remove it?
Postby james@amber » Fri 28.11.2008, 09:39
i just used some fairy liquid and a scourer. the only problem with using a scourer was it left the hose not quite as shiny, so something less abrasive would be better.
cheers
james
james@amber
Postby nitroman » Wed 24.12.2008, 11:37
Glass cooling hoses. Awesome.
nitroman
Postby dapinky » Mon 18.05.2009, 21:18
Hi everyone....after a bit of help here.......
.... I ordered a set of red samcos and they arrived last week, just in time to fit everything for Castle Combe whilst the turbo is going back on, coil packs, leads etc....
part way through the job, I realised that 2 hoses were missing from the set :(
I contacted James at Amber, and he has asked for the part numbers of the ones I have, so he can work out the ones I need.....
...however, as I have now fitted most of them, they ain't easy to get the numbers from.
Does anyone still have a set in stock that they havent fitted?
If so, can you I'D the 2 hoses from the below picture, and provide the Samco part number?????
Postby inkitin » Mon 18.05.2009, 21:35
I'd check that little person on the right of your photo if I was you!! :-D
Get a warrant for their toy box ! :wink:
91 SE Calypso Red
inkitin
Postby max and andy » Tue 19.05.2009, 01:19
There under the fourth floor board from the left. Does anyone do a generic hose kit for the S2? A&M
max and andy
Return to Upgrades
