Not starting
Not starting
Postby junks » Thu 27.11.2008, 09:09
So the bodywork is done & new tyres & wheels refurbed but now it won't start!
The immobiliser appears to be truning off but a bit strange as when I disconnect the battery the alarm sounds, there does not seem to be any way of stopping this & because of it I am thinking this may be the problem although it is turning over but no signs of life :(
2007 Europa S
2000 340R
2010 Evora IPS
2010 Elise/Exige Project
1973 +2 Elan
1959 Frog Eye
1964 Sunbeam Alpine GT
junks
Re: Not starting
Postby bobbrown » Thu 27.11.2008, 09:21
Have you checked the fuel pump inertia cut off switch?
Bob
Pacific Blue N/A
bobbrown
Re: Not starting
Postby junks » Thu 27.11.2008, 09:49
bobbrown wrote:Have you checked the fuel pump inertia cut off switch?
Bob
Yes - thanks, that was my first thought having had a problem with that before on an earlier Elan - seems ok unless of course it has developed a problem
Took a while to find it though as in a difference place to my 91 model!! :-D
2007 Europa S
2000 340R
2010 Evora IPS
1973 +2 Elan
1959 Frog Eye
junks
Re: Not starting
Postby bobbrown » Thu 27.11.2008, 09:52
So when you switch the ignition on the pump runs?
On mine the alarm system cuts the fuel pump.
Bob
Pacific Blue N/A
bobbrown
Re: Not starting
Postby junks » Thu 27.11.2008, 10:07
bobbrown wrote:So when you switch the ignition on the pump runs?
Bob
Not sure Bob - can you hear it as with the Elise type?? It does feels like no fuel but I've not checked plugs etc yet as I feel there is something amiss with the alarm system re my comments before
2007 Europa S
2000 340R
2010 Evora IPS
1973 +2 Elan
1959 Frog Eye
junks
Re: Not starting
Postby bobbrown » Thu 27.11.2008, 10:37
Although it is not loud, I can here my pump run when I switch the ignition on.
Pacific Blue N/A
bobbrown
Re: Not starting
Postby junks » Thu 27.11.2008, 10:46
bobbrown wrote:Although it is not loud, I can here my pump run when I switch the ignition on.
I'll have a listen then Bob & report back later mate - thanks ;)
2007 Europa S
2000 340R
2010 Evora IPS
1973 +2 Elan
1959 Frog Eye
junks
Re: Not starting
Postby theelanman » Thu 27.11.2008, 11:39
me too......its a whiring sound for about 2 seconds :-D
Re: Not starting
Postby WillB » Thu 27.11.2008, 12:19
Same ideas as on my text message! :-D
WillB
Re: Not starting
Postby junks » Thu 27.11.2008, 12:23
WillB wrote:Same ideas as on my text message! :-D
I would have given you some credit mate when I find out :mrgreen:
2007 Europa S
2000 340R
2010 Evora IPS
1973 +2 Elan
1959 Frog Eye
junks
