Hi-Spec rear conversion
Re: Hi-Spec rear conversion
Postby bobbrown » Wed 26.11.2008, 10:42
VAT
There should be some adjustments nessary due to changes in VAT so needless to say nothing will get paid for or ordered until the 1st Dec (Monday)
As the amounts are relatively small and will see how much is owed to people on completion of the Kits
Bob
Pacific Blue N/A
bobbrown
Postby Avonvilla » Wed 26.11.2008, 15:04
1. bobbrown PAID
2. Ailwyn - Going for BB Hi-Spec Fronts 16" 294mm x 24mm front 256mm x 24 rear PAID
3. Ailwyn (just the not-off-the-shelf bits) - Going for BB Hi-Spec Fronts 16" 294mm x 24mm front 256mm x 24 rearPAID
4. Elanlover (custom HiSpec front set up as per Bob's specs) - BLACK PAID
5. SuferPhil - Not sure yet, probably AP up front for the track car with the adjustable bias and 16" S2 wheels
6. Nige (300x28mm Front Discs - Hi Spec Billet 4 Calipers). PAID (Calipers (Black), brackets and hardware only 256mm discs and pads to follow).
7. Nitroman - Wilwood 6811 front willwood rear disc 298mm x 20.6mm 2 piece
8. Fubar1764 - Wilwood 6811 front willwood rear disc 298mm x 20.6mm 2piece
9. G UK - Hi-Spec 16" Fronts already fitted 240mm x20mm diameter rear
10. Richard K - HiSpec under 15" rim already fitted - going to S2 Wheels(PAID)
11. A B Munro - A P Racing front discs and calipers
12. Dico - currently have Wilwoods 16" kit up front, wanting to upgrade to BB's front Hi'spec 16" kit. PAID
13. Monty - BB`s 16" wilwoods front fitted. PAID
14. Router - HiSpec under 15" rim already fitted PAID
15. Avonvilla - 16" 6816 Wilwood's, 240/256mm x 20mm Caliper PAID BLACK
16. Gazza - (295mm AP Fronts) - 240/256mm x 20mm Caliper RED (PAID)
Avonvilla
Postby bobbrown » Wed 03.12.2008, 01:54
I am going to close this list very shortly as I need to get the calipers ordered.
I will be going down to Hi-Spec on Thursday as they are so slow to respond to emails it is a joke and I need ot make sure they understand what is required for the handbrake.
Please make sure if you have sent your payment is is marked on the list.
Bob
Pacific Blue N/A
bobbrown
Postby bobbrown » Wed 03.12.2008, 10:23
Tidy up
1. bobbrown PAID
7. G UK - Hi-Spec 16" Fronts already fitted 240mm x20mm diameter rear
8. Richard K - HiSpec under 15" rim already fitted - going to S2 Wheels(PAID)
9. A B Munro - A P Racing front discs and calipers
10. Dico - currently have Wilwoods 16" kit up front, wanting to upgrade to BB's front Hi'spec 16" kit. PAID
11. Monty - BB`s 16" wilwoods front fitted. PAID
12. Router - HiSpec under 15" rim already fitted PAID
13. Avonvilla - 16" 6816 Wilwood's, 240/256mm x 20mm Caliper PAID BLACK
14. Gazza - (295mm AP Fronts) - 240/256mm x 20mm Caliper RED (PAID)
15.ChrisB - (standard) 275 fronts 240/256 rear black
Pacific Blue N/A
bobbrown
Postby abmunro » Wed 03.12.2008, 14:00
Tidy up- Added ABMunro Paid
1. bobbrown PAID
9. A B Munro - A P Racing front discs and calipers, Black calipers please ( PAID )
abmunro
Postby surfboardfiller » Wed 03.12.2008, 23:41
Tidy up- Added SurferPhil Paid
1. bobbrown PAID
5. SuferPhil - Not sure yet, probably AP up front for the track car with the adjustable bias and 16" S2 wheels PAID
surfboardfiller
Postby bobbrown » Thu 04.12.2008, 11:09
Added paul back
1. bobbrown PAID
16.PaulW- Hi-spec 275 fronts Paid
Pacific Blue N/A
bobbrown
Postby bobbrown » Mon 08.12.2008, 17:52
List is now closed as I have placed the order for the calipers with Hi-spec.
Bob
Pacific Blue N/A
bobbrown
Postby RichardK » Mon 08.12.2008, 18:33
Hispec......now we wait ....and wait.....and triple check....eh bob!
RichardK
Postby bobbrown » Mon 08.12.2008, 18:52
Yes highly possible!
It took several phone calls/emails and an email with the list of calipers to get them to wake up, plus the mention of how do you want paid seemed to have the biggest effect.
I was suposed to get a phone call this morning but need less to say that never happened so I called them in the afternoon.
There will be some delay as the calipers need to have "special" levers made up for the hand brake cables + some colours take longer than others some thing to do with batches.
I estimate it will take 2/3 weeks to get this order together but allowing for Christmas we should see the kits ready for the first/second week in the new year.
Bob
Pacific Blue N/A
bobbrown
Postby bobbrown » Thu 18.12.2008, 16:59
Hi Spec are not what you would call a switched on company!!!!!!!!!!!
I had sent them a list of what was required, heard nothing from them so took a trip to see them to see if any progress had been made.
Well what do you know, nothing had happened since my last conversation with them.
I have at last got the order progressed a little how far it actually goes is anyones guess but I will keep on at them as it seems that is the only way this ever going to progress.
You would think as this is an order for a number of calipers they would be a little more keen than they have been todate lets hope my visit has had some effect.!!!
Bob
Pacific Blue N/A
bobbrown
Postby RichardK » Thu 18.12.2008, 17:23
Yep - that sounds about right... :twisted: ..at least you don't live too far away!! :shock:
Thanks for your efforts Bob, look forward to a late Christmas present ;-)
Richard
RichardK
Postby bobbrown » Sat 20.12.2008, 15:20
Here some pics of the disc and bracket (not finished) mounted on the hub carrier
Pacific Blue N/A
bobbrown
Postby bobbrown » Fri 23.01.2009, 00:43
Update as to current position.
Fronts calipers are ready for collection so will pick up Friday and check them against what has been ordered.
Those that have ordered only the fronts I will endeavour to get your kits out next week.
As for the rears I am still waiting on Jeff at Hi Spec sorting out the levers so they suit out handbrake cables (nipple end) plus I wanted the position of the cable actuation in a particular orientation (similar to the current rear caliper)
Once the levers are sorted it should not take them to long (I hope) to get the calipers produced.
I hope to pick up a dummy rear caliper Friday to check the clearances on the space saver and sort out the final bits like a return spring for the hand brake cable and to check the final positioning of the caliper on the hub carrier etc.
Bob
Pacific Blue N/A
bobbrown
Postby Gazza » Fri 23.01.2009, 15:35
Cheers for the update. Keep up the good work. :D
Gazza
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
Postby bobbrown » Fri 23.01.2009, 20:57
I now have all the front calipers and will get them off to people who need them as some are only upgrading the fronts.
If any one wants the fronts before the rears are ready please advise and I will try to get them off to you within the next week or so (still got some of the brackets to finish)
With referance to the space saver
The space saver will fit up to and including a 260mm x 24mm thick disk, I have checked it with a caliper and a 256mm disc and there is more than enough clearance.
Bob
House full of brake parts, hubs and bearings.
Pacific Blue N/A
bobbrown
Postby Elanlover » Fri 23.01.2009, 22:08
bobbrown wrote:The space saver will fit up to and including a 260mm x 24mm thick disk, I have checked it with a caliper and a 256mm disc and there is more than enough clearance.
Bob, you may (or may not) know how significant that is. In all the research I did with Brian to get a Wilwood rear caliper upgrade it was abundantly clear that the space saver was not going to fit at all. Now, if you can tell me that it will fit on the rear kit you're making for me then I might just have to fly over there and kiss your a$$. :smt008 Just your a$$ though. There are "some" lines i just won't cross. :wink:
Postby bobbrown » Fri 23.01.2009, 23:46
Elanlover wrote:Bob, you may (or may not) know how significant that is. In all the research I did with Brian to get a Wilwood rear caliper upgrade it was abundantly clear that the space saver was not going to fit at all. Now, if you can tell me that it will fit on the rear kit you're making for me then I might just have to fly over there and kiss your a$$. :smt008 Just your a$$ though. There are "some" lines i just won't cross. :wink:
This was only relevant for the rear as all front upgrades are far too large to allow the space saver to fit.
I think the trick is if you have a flat on the front, is to be able to transfer a rear to the front and fit the space saver to the rear.
Unfortunately this does not apply to Elanlover as your rear calipers are on 273mm discs so I guess is a case of carry a full size spare (assuming you can get a 17” rim in the boot) or can of puncture repair with you and have breakdown cover if you want to be 100% certain. Mind you in many years and 10’s of thousands of miles I have only had one puncture while driving, several while car has been parked but only one on the road so the odds are good you will never get one.
Bob
Pacific Blue N/A
bobbrown
Postby bobbrown » Fri 06.02.2009, 10:34
It looks like Hi-spec have finally got around to making the rear calipers and they should be ready for collection in about a couple of weeks time. Knowing Hi-spec that may slip so I am not holding my breath but at least they are making progress.
I should have my end done by then and will get the kits off as they are ready for dispatch.
If anyone want to wait untill Donington please advise and I should be able to get some off via Phil/Geoff
Bob
Pacific Blue N/A
bobbrown
Postby bobbrown » Fri 06.03.2009, 12:59
Grrrrrrrrrrrr!!!!
Slip is an understatement, been trying to get an answer out of them since last week and Roy did not return my calls but at last got a sort of answer today (Friday)
Some of the rear calipers should be ready for collection mid part of next week so I can complete the final mounting position (60 holes to drill and tap) which will mean some of these kits should go out the door week after next.
Bob
PS If anyone wants to collect at Donington let me know
Pacific Blue N/A
bobbrown
