Steering rack removal
Postby Specky » Mon 29.12.2008, 19:17
Who's removed the steering rack then ?
Mines ready to come out, (in theory) all disconected...
The car is on axle stands... So i can't disconect the pongeron...
Oh.... it's the project car as well, so I have more acess than I know what to do with...
But it's that lower UJ spline how do you get it out of the tub...
A pic to show how much access I have...
Any clues
Re: Steering rack removal
Postby Enright » Mon 29.12.2008, 19:25
Couldn't you move the axle stands to the jacking points just behind the A-panels and then remove the prongeron?
Postby Specky » Mon 29.12.2008, 21:30
Enright wrote:Couldn't you move the axle stands to the jacking points just behind the A-panels and then remove the prongeron?
Would that give enough room....
I'll have to put some bolts back in the tub that hold it onto chassis...
The tub is so weak thou and to top it off the front jacking points are failing.... Ummmm
Removing the Prongeron would enable me to remove the exhaust as It won't seperate...
I just hoped there was another way...
Postby Paul.P » Mon 29.12.2008, 23:04
Monty has done this, i'm sure he will be along in a bit !
Postby Monty » Tue 30.12.2008, 00:19
With a propper M100 you need to remove the Prongeron lol, don`t forget you need to remove the pinch bolt completely from the top UJ and it might help by undoing the steering column to give you some movement to have a pull :smt081
Postby muley » Tue 30.12.2008, 00:24
I've not done it myself, but here's a thread including candle's take on the job.
viewtopic.php?f=37&t=11123&start=20&hilit=rack
Good luck
Postby Specky » Tue 30.12.2008, 00:36
Monty wrote:With a propper M100 you need to remove the Prongeron lol, don`t forget you need to remove the pinch bolt completely from the top UJ and it might help by undoing the steering column to give you some movement to have a pull :smt081
Cheers Monty... :lol:
The steering column's removed, the UJ's released, the rack's ready to come out, (Round peg in square hole, I just can't get it out)
I guess I'll just have to bite the bullet and take the Prongeron out, then put it back in once I'm done.... We don't want those front wheels spreading do we.... :wink:
Cheers again Monty..."propper M100"...What he like...
Postby Specky » Tue 30.12.2008, 00:59
muley wrote:I've not done it myself, but here's a thread including candle's take on the job.
Good luck
Cheers Jim,
I did a search earlier and saw that thread, but only read it thru half way.... :roll: .... and thought nope that doesn't help, but it sorta of does...
I'll take a few Pics in case it helps some one else....
I guess it's just one of those jobs....
Postby RayD » Tue 30.12.2008, 16:24
Dave,
Would you do me a favour...when you have time.
See Here
On your car you might be able to see which colour wire is going to terminal 6 on the rheostat module and what route it takes to get there.
I want to change the wire for one from the side light circuit... somewhere where it’s easier to get to than under the dash.
Ray
RayD
Return to Chassis & Steering
