by dapinky » Sun 11.01.2009, 18:42
I'm on nights so was asleep when this first got posted.......
....Gareth is mostly right, Bob is partly right, but with slightly missleading info, and you dont need a new chassis anyway!
Basically, the difficulty on the info so far is that they have all been correct at various points of time in recent history, it is not right to say that Spyder get away with it on the +2 (1967) so it is right - the rules from 1967 were changed!
Basically, for a 1989 vehicle, it will have a VIN (Vehicle Idenbtification Number) which will be 17 alpha-numeric characters - this is often referred to as a 'chassis number', but that is what you would have on an old type elan, europa, herald, vittesse etc. Originally it started because the chassis was the 'standard' part of the car, and then the bodywork was attached by various coachbuilders etc - just think how many different companies put boddies onto Austin 7s.
When the 'norm' was to produce vehicles with a monocoque construction, the term chassis number was dropped in favour of VIN.
There is no legal requirement to have the VIN on the chassis for a non-monocoque car - but they often are (You'd have to ask Lotus).
If you chose to use a second-hand chassis, it will not affect the VIN of your vehicle, or the registration, as long as you use enough of the original parts (or new items if 'service items' from the old car - each component is given a number of points by DVLA, and you need to ammass a certain number of 'original' or 'service' parts points to retain a registration.
These rules are irrellevant here, and would only become valid if you were trying to (for example), fit a second-hand chassis and then pass the car off as the other vehicle identity. (ringing a stolen car etc etc) or trying to make a car look older/younger than it is for financial gain.
If you had a second 'frost silver' elan which you were trying to pass off as IB3, you may be accused as trying to make a gain, but as it is the actual car, you aren't.
The whole thing is a bit of a minefield, and i can't explain it very well in a few paragraphs, but if you need any further info, drop me a line and we can have a chat - it's easier in a conversation.
Suffice to say, if you decide to fit either a new or a second-hand chassis, or repair the original, it will not affect anything.
If you use a chassis with a number already stamped, you are legally allowed to either remove, cover or fill the number, and then either stamp the correct one in or not as you wish.
Be aware though, that you should retain all paperwork, otherwise, should someone ever do a full examination on the vehicle for either crime, accident or any other reason (provenance?). if the chassis displays a number different to the VIN, you will need to prove the discrepancy to avoid someone thinking that you are on the fiddle!!!!! (assuming they would either know where to look, or just happened across it).
