Mellow Yellow
Re: Mellow Yellow
Postby lotos » Thu 05.02.2009, 20:27
Thanks! Once I hear back from the gods of the forum if these lug bolts will work, I will have new wheels and new pics up! :poke:
lotos
Re: Mellow Yellow
Postby DeeAitch » Thu 05.02.2009, 21:46
lotos wrote:Thanks! Once I hear back from the gods of the forum if these lug bolts will work, I will have new wheels and new pics up! :poke:
You need to check the taper angle is 60Deg as well.
Also be sure to check that the last few threads in the hubs are not corroded - mine needed chasing out when I changed the bolts last year.
DeeAitch
Re: Mellow Yellow
Postby lotos » Thu 05.02.2009, 22:23
DeeAitch wrote:You need to check the taper angle is 60Deg as well.
Yep, 60 degree angle. Think the lengths will work?
lotos
Re: Mellow Yellow
Postby lotos » Sun 01.03.2009, 06:55
What fun are upgrades if you aren't familiar with the car beforehand? I was discussing the chip with Algirdas, I said that I found the car already quite fast when the turbo kicks in, and he shook his head, smiled and said, "Just wait 'til you have a chip." I think it'd be fun to get a GTECH to see some real-world numbers before and after, too.
Anyway, no other updates yet, other than my darned headlight is still fussy going up. I guess the rebuild is unavoidable.
lotos
Re: Mellow Yellow
Postby tweetdriver63 » Sun 01.03.2009, 07:03
Randy, I ditto Algirdas. My car had a Superchip and MBC when I got it. Recently, I tossed those in the spares box, in favor of an Everest chip. The car has the stock exhaust and intake (except for BOV), and it's a noticable difference. I was already running with extra boost (compared to stock) at about .75 bar, and with everything stock, the Everest smoothly gives me .9 bar, and I can defo tell the dif.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Re: Mellow Yellow
Postby lotos » Mon 09.03.2009, 19:59
Went on a beautiful 2-hour group drive yesterday with the local Lotus group - included one other M100, an Elise, a Seven replica, a 60's Elan, three beautiful Elites, an Eclat, and a few Esprits. Roads up and down the foothills kept you at attention the whole time, your right hand never stopped shifting. It was a great time, but I know I can take corners faster than I felt comfortable doing in this first real drive in an M100. I need to trust the car a little more than I'm used to.
The stock brakes are certainly not ideal, but they're not the worst thing ever, either. I will probably get a nice set of pads in there and start saving up for the Wilwoods by bobbrown.
I've just ordeded the Rodney Dickman special (headlight repair kit) - I also picked up speakers last week, need to install them. A set of four 5.25" Alpines with an aimable tweeter, they were inexpensive and will hold me over until I redo the sound system down the road someday.
Not sure why the photos are showing up in the post... I'll try something here:
Lotus Colorado Drive, March, 2009
(77.64 KiB) Downloaded 251 times
(37.17 KiB) Downloaded 251 times
lotos
Re: Mellow Yellow
Postby nitroman » Tue 10.03.2009, 07:11
You guys should switch cars every 5 miles just to have the experience. Of course there'd have to be agreement on how aggressively to drive, but how else is one ever to drive an Elite?
nitroman
Re: Mellow Yellow
Postby lotos » Thu 19.03.2009, 02:44
So... now my headlight goes up and down fine, except the motor runs for about ten seconds while the knob on top spins furiously. I have the repair kit in hand - can someone point me to directions on what to remove to gain access to the delrin bushings I need to replace?
lotos
Re: Mellow Yellow
Postby nitroman » Fri 20.03.2009, 03:34
There are 3 small black screws on the side of each motor. The L & R are different (not interchangeable). One of the motors has the shaft coming out through the removable side panel, the other has the service panel on the "backside", the side opposite the shaft.
I've visually looked at dozens of similar motors, which obviously have the exact same internal gears, etc., but they all seem to vary slightly in subtle extensions of the motor body or in securing screw points; just enough so that the motors are not interchangeable with other cars.
nitroman
Re: Mellow Yellow
Postby lotos » Fri 20.03.2009, 23:54
Muchos Gracias - I should be able to get to it this weekend. So I don't need to contort myself or remove body panels to get these out of the car and work on them?
lotos
Re: Mellow Yellow
Postby Doug » Sat 21.03.2009, 02:08
there's a write-up in the LEC site and prob on the WIki too, Randy.
Re: Mellow Yellow
Postby lotos » Sat 21.03.2009, 21:46
sigh... my problem one is the passenger side - so that means I have to jack up the car and remove the wheel to access it? groan. Maybe I'll tackle this when I change wheels.
lotos
Re: Mellow Yellow
Postby nitroman » Sat 21.03.2009, 22:14
lotos wrote:sigh... my problem one is the passenger side - so that means I have to jack up the car and remove the wheel to access it? groan. Maybe I'll tackle this when I change wheels.
It's more involved than just swapping wheels. I wouldn't halt the job on that score.
nitroman
Re: Mellow Yellow
Postby lotos » Sat 21.03.2009, 23:49
I'm saying that I really don't have the means to do all that right now - I've got a jam-packed garage and hardly any tools (or skills ... :smt088 ). I'll try to tackle a few of these looming projects with a buddy who's offered to help. He's an Infiniti technician who can get us into their shop off-hours. So... this will go on that list I guess. Unless one of you is flying to Colorado soon and wants to help :?: :?: :?:
lotos
Re: Mellow Yellow
Postby lotusgirlmarie » Sun 22.03.2009, 03:45
I was there two weeks ago.... :shock:
lotusgirlmarie
Goddess
Re: Mellow Yellow
Postby lotos » Mon 23.03.2009, 04:57
The driver's seat rails have a wire connect nearby... one of them had either pulled out or broken off, I didn't inspect carefully. What's it for?
lotos
Re: Mellow Yellow
Postby Specky » Mon 23.03.2009, 06:16
The wire is for the tel-tale light on your seat belt buckle...
No idea what the hole is for...(Just thought, where's your inertia switch?)
Re: Mellow Yellow
Postby nitroman » Mon 23.03.2009, 08:11
Specky wrote:No idea what the hole is for...(Just thought, where's your inertia switch?)
Exactly.
When your car gets a good knock (accident, etc.) it'll shut off the fuel pump, and you'll have to press the button at the bottom of the hole you discovered to get the fuel flowing again.
To be successful at hit-n-run, you need that info.
PS, some peeps alarm systems also flip the inertia switch! My original red Elan was that way. You can create your own cheap anti-theft system by pulling up the plunger when you leave the car.
nitroman
Re: Mellow Yellow
Postby esprit888 » Mon 23.03.2009, 08:12
Right on both counts. The seat belt wire is not connected to anything as at the time they were not mandatory in the U.S, and the hole is for what we all hope we will never have to stick our finger in there for :lol:
Specky wrote:The wire is for the tel-tale light on your seat belt buckle...
esprit888
Re: Mellow Yellow
Postby lotos » Wed 01.04.2009, 20:24
FYI for those interested - Tire Rack has the BBS valve stems in stock, they're $4.50 a piece, $30 total including shipping for four.
lotos
