Steering wheel fitment
Postby G UK » Sat 27.10.2007, 20:44
Got this steering wheel (Momo?) included when I bought my S2 although it wasn't fitted. I assume I either need to replace the Nardi boss with a Momo one or get an adaptor and shroud to fit it. What I'm not sure about is how the horn will work.
I take it I attach the wire to one connector but how do I ensure the return circuit? Or am I being dumb and I just bolt on to the adaptor/new boss?
Edit: Found an nardi to momo conversion adaptor on Ebay for £15
Clicky
Cant find a shroud so will probably make my own from some corrugated plastic tube.
G UK
Re: Steering wheel fitment
Postby cyc0140 » Wed 14.01.2009, 09:47
Hi all, sorry to jump in in the middle but I noticed that many of you are using nice momo steering wheels. I recently bought a brand new '"red" highlight Momo Pilota steering wheel but I could not find the right Boss kit adapter. My Elan is red and both the seats has been re-upholstered in black leather with red stitching, hence I would really love to fit the Pilota to complete the look. My Elan is UK RHDrive version 1990 Turbe SE. Could somebody advice where and which model Momo or OEM adapter I can use. Thanks !
cyc0140
Re:
Postby lotos » Sun 22.02.2009, 22:16
Ekapol wrote:As much as I want to add Elise airbag wheel to my car, the design of S2 Elise wheel will look out of place with our Elan interior.
I think it would look better than the GM p.o.s. in place now... What would be involved if you had an Elise airbag wheel to put into an M100?
lotos
Re: Re:
Postby Elanlover » Sun 22.02.2009, 22:35
I'll let you know in May (when my other little projects are completed) since I now have all the parts for an Elise airbag wheel sitting in my basement.
Postby lotos » Mon 23.02.2009, 01:49
I really want to do this swap. But... the color is certainly wrong. I'm wondering if the small amount of leather on the Elise wheel could easily be dyed to match better - the Elise wheel is black with silver trim, the Elan interior is gray:
lotos
Postby Doc Fizzix » Mon 23.02.2009, 05:55
Just a comment, that is a strange photo, I see the top is up but know one is in the car. Did you crawl behind the seats to take that picture, maybe in the storage area :D
Doc Fizzix
Postby lotos » Mon 23.02.2009, 06:08
hehe , I just stuck my arm behind the seat and took a few in hopes one would look decent :) You can see my wrinkled sleeve in the mirror
lotos
Postby Elanlover » Mon 23.02.2009, 14:10
lotos wrote:I really want to do this swap. But... the color is certainly wrong. I'm wondering if the small amount of leather on the Elise wheel could easily be dyed to match better - the Elise wheel is black with silver trim, the Elan interior is gray:
Yes but the fascia is all black as is the instrument cluster. I don't think it will look that bad. There are lots of folks in the UK who have installed new steering wheels that are black (the UK version didn't have an airbag making it easier to swap the steering wheel). You could always paint the aluminum a different colour.
Postby Elanlover » Tue 24.02.2009, 14:53
Ok, there are 2 complete Elise airbag steering wheels (hard to believe since it took me 6 months to find a good used one without the airbag) on eBay as we speak. Here and here.
These look like they can be had for a very good price. But, here's what you have to look out for. First, you want to make sure they are coming with the plastic rotary connector on the back. This part, while being a GM part and available from Lotus, is stupidly expensive (I do have 2 extra's though :wink: ). Second, and this is the hard part, you need the hub adaptor. This is NOT avaiable from Lotus as a seperate part and while a used connector can sometimes be found, the hub adaptor is virtually impossible to find.
If you can't get a hub apadtor then there are some possible options. My quick looks indicate to me that the splines on the Elise hub adaptor will not match up to the steering column in the Elan although I've not yet verified that. So, the Elise hub may, in the end, be useless anyway :roll: That means getting a custom made hub, modifying the Elise hub (not likely possible) or adapting the Elan hub to the back of the Elise wheel are all possible ways to overcome this challenge. This is assuming the airbag connectors are compatible or can be made to be compatible.
I mention all this only because some folks (like me) would really like to fit the Elise airbag wheel to the Elan. Its not a direct transplant to be sure but i may be possible. So, if you spend the money on one of these do so knowing that it may end up being a waste (although I'm betting something can be done to make it all work).
Postby tweetdriver63 » Tue 24.02.2009, 17:37
Elanlover wrote:Ok, there are 2 complete Elise airbag steering wheels (hard to believe since it took me 6 months to find a good used one without the airbag) on eBay as we speak. Here and here.
That second one (the one that says "reserve not met") had the reserve met with a $250 bid when I saw it last. If anybody's wondering what the reserve is.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby Elanlover » Tue 24.02.2009, 19:02
After looking over the first auction I listed I can see form the additonal pics that it does not include the contact ring or hub adaptor. I would bet that the second one is the same but someone could ask the seller about it or have them post a pic of the back of the steering wheel.
Postby cliffyg » Wed 25.02.2009, 07:22
what I don't understand: we see a pic of a m100 with the elise wheel installed. yet the thread indicates that it might not be possible. Obviously it is. Can anyone speak to the hub adaptor issue? did anyone ever talk to anyone who has done this installation? what did they do? I'd love to do this--I'm with tweet--once you've been in a smashup and an airbag has kept you from being damaged it's hard to drive without one.
cliff
"Honey are you sure this car can handle this speed??????"
cliffyg
Postby lotos » Wed 25.02.2009, 07:26
I'm glad my Photoshopping skills are proving so successful. Maybe I should start doing those fake celebrity nude shots and selling them to the tabloids..
lotos
Postby tweetdriver63 » Wed 25.02.2009, 07:29
cliffyg wrote:what I don't understand: we see a pic of a m100 with the elise wheel installed. yet the thread indicates that it might not be possible. Obviously it is. Can anyone speak to the hub adaptor issue? did anyone ever talk to anyone who has done this installation? what did they do? I'd love to do this--I'm with tweet--once you've been in a smashup and an airbag has kept you from being damaged it's hard to drive without one.
cliff
Randy's (Lotos) pictures above are of the Elise wheel just sitting in the proper position, but not actually installed. Installation is apparently tricky, at best. I don't like the looks of the GM wheel, but I also don't think the Elise airbag wheel really fits the interior. Personal taste. I was about to attemp a Corvette wheel a while back, but didn't get around to it, and didn't have the money to spare. It appeared to have the standard GM stuff, which on the back of the wheel, looked like all the mounting stuff would line up, so if the splines did too, it might be easy. It was a much more attractive wheel than the one we have.
'91 Elan SE
tweetdriver63
Postby Elanlover » Wed 25.02.2009, 14:04
tweetdriver63 wrote:.......... so if the splines did too, it might be easy..........
Keep in mind that the steering column is not a typical GM part. Its an Isuzu part. So, its unlikely that a GM wheel will just pop on. I don't even think the Esprit wheel, which is identical to the Elan wheel, will simply pop on. The hub's are different even if the wheels are the same.
Postby cliffyg » Wed 25.02.2009, 16:56
lotos wrote:I'm glad my Photoshopping skills are proving so successful. Maybe I should start doing those fake celebrity nude shots and selling them to the tabloids..
Yikes!!! :oops: :oops: :oops:
but it does look good. And Randy, can you photoshop me a nude pic of lindsay lohan?? Thanks mate.
cliff
cliffyg
Postby lotos » Wed 25.02.2009, 17:05
lotos
Postby lotos » Thu 05.03.2009, 02:09
Elanlover wrote:I don't think it will look that bad.
lotos
Postby esprit888 » Thu 05.03.2009, 02:31
Hmmm, Oh! I just happen to have the Elise wheel (non SIR) with the adaptor that i am going to fit to mine so did i make a bad buy? :-D (see below) My BIG question is, after fitting a custom Raid SIR wheel to my Esprit, which had the same Pontiac airbag wheel as the M100, an in-line resistor was required to stop the air bag light from staying on. Has anyone fitted an alternative non SIR wheel to a Fed or Canadian car and had issues with the SIR light ? or does it go out and stay out for good (unlike the Esprit!)
esprit888
Postby superbad » Thu 05.03.2009, 03:50
Hotness. That's going to look excellent.
superbad
Return to Interior
