by nitroman » Mon 02.03.2009, 04:05
I drove 5 houses down the street & returned. There was a faint click, click, click; which turned out to be the INSIDE balance weights striking the hydraulic line on one side. I'll put it up on ramps my next available day and adjust them. Not to denigrate anyone, but I have no idea why there is a 90-degree metal elbow (screwed into the caliper) which the hose is attached to. That keeps it too close to the wheel. In my mind the hose should immediately put distance between itself & the wheel. I'd simply replace the 90-degree piece with a straight fitting. I would imagine Wilwood carries such a thing, for the rest of you who've yet to install yours.
I'll not comment on brake feel , as I obviously didn't go fast enough to draw conclusions. I will say though, that pedal travel is HUGELY shorter than with the larger 6816 calipers. Please recall that I have neither the large 6816 nor the small 6806 caliper, but rather the midground 6811.
Oh yes, the clearance between the caliper & the S2 wheel is REALLY tight. I'd say it's less than half the distance it is on the Fed wheels.
- Attachments
- brake-peek (Small).JPG (39.35 KiB) Viewed 6092 times
- brake-full (Small).JPG (35.43 KiB) Viewed 6093 times
- brake-close (Small).JPG (35.17 KiB) Viewed 6094 times
nitroman on Mon 02.03.2009, 18:52, edited 2 times in total.
