federal stiffy anyone?
Postby bratboy_y2k » Fri 13.03.2009, 22:47
hey folks, i was just talking to a friend at the local bmw dealership. guess what he builds in his spare time...yes thats right, exhaust bits. i guess he has to be able to since he just twin turboed a v8 beemer. he did the work on the intake and exhaust. i spoke to him about doing a batch of stuffys and he said forsure but wants to get an idea of how many. how many people are interested? he will also do ehaust manifolds if anybody is interested.
bratboy_y2k
Re: federal stiffy anyone?
Postby lotos » Fri 13.03.2009, 22:52
Sure, why not?
1) lotos
lotos
Postby esprit888 » Sat 14.03.2009, 06:18
Sure, why not?
1) lotos
2)esprit888
esprit888
Postby tweetdriver63 » Sat 14.03.2009, 06:45
I know I'm going to sound like an idiot, but what is this bit for, exactly?
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby lotos » Sat 14.03.2009, 13:08
Connects your turbo to your exhaust, removing the restrictive factory pieces.
Elanlover wrote:Technically, the "stiffy" is a combination PCE and turbo exhaust manifold all-in-one piece. The PCE is only a replacement for the pre-cat and doesn't include the turbo manifold - it bolts to the bottom of it.
lotos
Postby Doc Fizzix » Sat 14.03.2009, 13:36
I think nitroman's pre-CAT eliminator does away with the need for a "stiffy"
Doc Fizzix
Postby lotos » Sat 14.03.2009, 18:12
I don't think those are available though.
lotos
Postby tweetdriver63 » Sat 14.03.2009, 18:17
Sure, why not?
1) lotos
2)esprit888
3)tweetdriver63 (what sort of price?)
'91 Elan SE
tweetdriver63
Postby esprit888 » Sat 14.03.2009, 20:36
Thats what i thought too, if a PCE is available i would take one today :)
Doc Fizzix wrote:I think nitroman's pre-CAT eliminator does away with the need for a "stiffy"
esprit888
Postby nitroman » Sun 15.03.2009, 03:49
esprit888 wrote:Thats what i thought too, if a PCE is available i would take one today :)
The PCE is available for $160 by contacting Stan's Headers directly.
nitroman
Postby Enright » Sun 15.03.2009, 21:05
They're also £92 from Piper, which at the present exchange rate must be pretty competitive.
http://www.pipercams.co.uk/exhaustshop/ ... ts_id=4440
Postby esprit888 » Mon 16.03.2009, 00:51
As crazy as it sounds i believe you are right ! It would be cheaper to buy the Piper PCE and air mail it from the UK to the west coast of Canada (at a rate of 1.78 $CDN to 1GBP = Approx $213 CDN including shipping) than it would be to buy it from Stans in Seattle (just an hour down interstate 5) at 0.76 $US to 1 $CDN (approx $245 CDN including shipping) Hmmmm, what else do i need over the pond :D
Enright wrote:They're also £92 from Piper, which at the present exchange rate must be pretty competitive.
esprit888
Postby lotos » Mon 16.03.2009, 01:06
Maybe we could do a group buy and Stan would cut us a good deal...
lotos
Postby nitroman » Mon 16.03.2009, 03:56
lotos wrote:Maybe we could do a group buy and Stan would cut us a good deal...
FYI the last group-buy was $125 with a minimun order of ten.
nitroman
Postby lotos » Thu 26.03.2009, 03:28
So.. a stiffy replaces both Pre-cat and downpipe, right? So this is technically better than a PCE (Piper, Stan's, etc) ?
lotos
Postby Doc Fizzix » Thu 26.03.2009, 04:29
lotos wrote:So.. a stiffy replaces both Pre-cat and downpipe, right? So this is technically better than a PCE (Piper, Stan's, etc) ?
Depends on flow, how is the flow through the cast stock pipe and then PCE compared to the flow through a "stiffy". The answer will really depend on the overall workmanship and flow testing of the "stiffy", I originally think the purpose of the "stiffy" was that it eliminated the pre-CAT since Stan's pipe was not available, but now that Stan's PCE is available again I think the Nitroman's (Stan's) PCE is the best way to go.
Doc Fizzix
Postby dapinky » Thu 26.03.2009, 10:40
My understanding is that the stiffy was designed with the purpose of eliminating the Pre-cat (as that is the greatest restriction), and it was designed to incorporate a pretty-looking tubular wastegate manifold, so that the whole thing looked more 'integrated' when installed between the turbo wastegate and the stainless front pipe, as well as giving a respectable weight saving.
Due to the tight spaces involved, and the small radius bends, it was/is quite a feat of engineering to produce, and i take my hat off to the original designer.
However, when the PCE came along and just replaced the cast iron dustbin, leaving the iron wastegate manifold, it was a far simpler (and therefore cheaper to produce) item.
It doesn't look quite as sexy, and there is less (but still significant) weight loss......
....however, it actually gives better gas flow than the stiffy (under top boost conditions).
Without going into the theories of thermal and fluid dynamics, it all comes down to the routing of the gas once it has gone through the wastegate (so obviously, only comes into play when the wastegate is open, ie under heavy boost!).
The original cast iron wastegate manifold has a seperate channel casting for the main exhaust flow and the wastegate flow, which merge a short distance down the pipe, before all entering the pre-cat in one lump, the stiffy merges the flow a lot further up (at the flange).
Now, there is a theoretical way to ensure that the 2 channels merge at the optimum point, but every case is different, and it just so happens that the Lotus engineers got it right with the original design (or at least, as right as they could with the space availlable!).
In an ideal world, the 2 channels would actually be 2 seperate round pipes, with lovely smooth radii, merging about 140mm from the wastegate, and then passing into a single round pipe over a distance of about 50mm. Clearly that is not possible with any road car, unless there is a hell of a lot of space availlable, so we go with the easiest compromise.
Actually, the difference between what we have, and the perfect set-up is not huge, so on a road car is somewhat irellevant - and the difference between a stiffy and a PCE is (likewise) not huge.
Personally, i love the look of the stiffy, but i like the gains given by a PCE, i am prepared to accept that the extra weight is more than made up for in the potential for extra power release, and the cost and availlability make it a no-brainer to me :-D
Postby lotos » Thu 26.03.2009, 15:26
Geez - you ask a question and get a complete reasoned reply. Is this a web forum or a cotillion? I appreciate it!
lotos
Postby esprit888 » Fri 27.03.2009, 08:44
Well i told my wife i was getting a federal stiffy and she's never been the same since ! :banana: , so now what do i do ? Is a Fed stiffy available anywhere right now? (my wife wants to know)
esprit888
Postby PiperRS » Fri 27.03.2009, 15:13
I am happy to look at different carriers to see if i have a way of sending a batch of our PCEs to the US if a few of you wanted to organise a group purchase.
As they would all be going out of the EU you would not pay Vat either so that helps. The unit cost would be £80.00 then :D
Kind Regards
Tom Edmunds
Race Exhaust Development Dept
Piper RS Ltd - Cams & Exhausts - 01303 245300 - http://www.piperexhausts.co.uk
PiperRS
Return to Exhaust
Users browsing this forum: Google [Bot] and 6 guests
