max and andy wrote:Is a stiffy a PCE ?
max and andy wrote:And whats the view on exhausts Peco Or Piper whats the best ?
max and andy wrote:Is a stiffy a PCE ? And whats the veiw on exhausts Peco Or Piper whats the best ?
max and andy wrote:If i get a PCE.Will the old exhaust manifold fit? Andy
HJ2 wrote:Yes there is: Cybox (PECO) (whoops, Mini was ahead of me, but see my message a few posts up)
The Ring stays, true, but compared to the 2"restriction it is a restriction beyond measuring capabilities. It is possible that it makes the flow even better. The ring brakes up the flow, causing turbulence. The trubulence makes it easier for the mainflow to pass the 2"orifice restriction.
Complex matter that cannot be answered without FEM analysis, backed up with actual experimental measurements. Luckily even without analysis it is safe to say that you cannot feel if the ring is still in place or not while driving
HJ2 wrote:When you are talking about a swap from empty pre-cat housing to a stiffy: Absolutely true!
I however talked about empty pre-cat with, or without the ring. The difference is not a couple of HP in this situation...
I am sorry if i didn't make myself clear![]()
nitroman wrote:HJ2 wrote:When you are talking about a swap from empty pre-cat housing to a stiffy: Absolutely true!
Ah contraire, the PCE is worth much more than 2hp. Have you had occasion to scientifically compare the before/after effects of replacing this one component only? I have. Those 2 horses must be Clydesdales! Turbo lag is also almost eliminated. I had the 2.5" exhaust on first, with a hollowed precat. Only after experiencing this did I install the PCE.
. From a flow point of view a replacement with a part with smooth internal curves is better. This also gets rid of the orifice in the pre-cat wich acts as a restriction.
I do have some experience with rocket engines internals though...
)max and andy wrote:How easy is it to remove the pre cat? My kwickfit didn't want to know. They said they would have to drop the front sub frame to fit the exhaust. Andy
