Rear Hub/Disc conversion second run + Hi-spec brakes
Re: Rear Hub/Disc conversion second run
Postby lotos » Wed 25.03.2009, 00:32
I'm too uneducated to really understand if/why I need this...
lotos
Postby bobbrown » Wed 25.03.2009, 00:43
lotos wrote:I'm too uneducated to really understand if/why I need this...
It was design and developed to allow the use of a low cost disc to be use instead of the current rather expensive combined disc/hub.
The hubs although not that cheap but when combined with the disc still work out cheaper than the current setup and do allow you to replace the rear discs should the need arise with out replacing the whole.
Also should you need /want to upgrade the rear brakes to return the brake balance to standard then this is a must. Other wise you can continue with stock.
It is worth noting that probably more rear discs in the UK fail due to rust deposits and the MOT than actually wear out, prolonged lack of use, laid up for the winter, sticky pins etc all contribute.
Bob
the list continues
1. alexg
2. whippit
3. Jimmer
4. martin_bailey_1
5. Max and Andy
6. Andy_J
7. Alan (ab2cv)
Pacific Blue N/A
bobbrown
Postby lotos » Wed 25.03.2009, 01:04
Thanks for the excellent explanation - my smarts just increased.
lotos
Postby BFG in the BRG » Wed 25.03.2009, 14:21
I agree BB, having just had my car fail on corroded rear disks :roll: .
Cost to replace in total, including reconditioned disks, new bearings, and pads from SJ's £140 ish, although I was minded to do the bearings anyway since they've been in for about 10 years.
Cost in the future - bearing in mind I won't have to ponce around with the bearings - probably £30 ish for disks and pads, and a lot easier to do, wheel off, calliper off, old pads off, old disk off, new disk on, new pads on, calliper on, wheel on.
Of course this is assuming everything comes off easily etc
Just to let you know,
This is the last Group Buy I am doing,
ever....
no it is.....
really.......
definitely no more.....
ever......
unless it is a good price.....
or an improvement.......
or will save money in the long run.......
:mrgreen:
the list continues
1. alexg
2. whippit
3. Jimmer
4. martin_bailey_1
5. Max and Andy
6. Andy_J
7. Alan (ab2cv)
8. BFG in the BRG
Alas soon to be Elan-less
BFG in the BRG
Postby Exbury » Thu 26.03.2009, 01:07
Great pics, I understand a lot better now......can I get the wedding out of the way first :D :?: actually probably good idea to get it done first......
Going to have to run this one past the brother (silent partner!!), probably will say yes :shock: ......wonder if the car will pass the current MOT on its brakes.......what numbers do you need to make the deadline? Especially if BFG needs his MOT'd soon....
Exbury
Postby bobbrown » Thu 26.03.2009, 01:27
Exbury
Wedding that's no excuse, as for how bad the rear discs have to get before they fail is down to the Mot guy but I had an advisory on the Mot 2 years ago so they got replaced at great expence and although the discs did not look to bad on the outside face the inner face was almost completely covered in a layer of rust which is very hard and does not wear off.
BFG when for a re-ground set of discs from SJ for the Mot cost (around the £95.00 mark) but is still getting the hubs as the reground discs will still have a minimum thickness of 10.9mm when new they are 12.65mm so if you have a pair part worn say 12mm and then grind 0.2mm off each side you are down to 11.6 so not that far to go to the minimum.
As for numbers I was going to leave it at least untill after Donington as you can not tell what interest that may introduce.
Bob
Pacific Blue N/A
bobbrown
Postby vi11ain » Fri 27.03.2009, 19:40
Another one for the list - I was hoping this would come up soon!
Ben
1. alexg
2. whippit
3. Jimmer
4. martin_bailey_1
5. Max and Andy
6. Andy_J
7. Alan (ab2cv)
8. BFG in the BRG
9. Ben (vi11ain)
...of the plot
vi11ain
Postby Exbury » Fri 27.03.2009, 20:25
You can put me down as a Likely and I will confirm next week. Are costs likely to decrease the more numbers there are? :D Also a Likely on the handbrake cables, in for a penny and all.....
Exbury
Postby Exbury » Fri 03.04.2009, 16:17
vi11ain wrote:Another one for the list - I was hoping this would come up soon!
Ben
1. alexg
2. whippit
3. Jimmer
4. martin_bailey_1
5. Max and Andy
6. Andy_J
7. Alan (ab2cv)
8. BFG in the BRG
9. Ben (vi11ain)
10. Exbury (in for a penny.....)
Exbury
Re:
Postby CJ101KT » Wed 15.04.2009, 19:13
I am defiantly up for another run of these as I have missed out on the first run of the rear Hi-Spec conversion and after being so impressed with Bobs hard work on the front Wilwood upgrade I had last year, I would also like to upgrade the rears, so this is a must. Hope for a second rear conversion run lol.
01. alexg
02. whippit
03. Jimmer
04. martin_bailey_1
05. Max and Andy
06. Andy_J
07. Alan (ab2cv)
08. BFG in the BRG
09. Ben (vi11ain)
10. Exbury
11. CJ
CJ101KT
Re: Re:
Postby BigErch » Mon 20.04.2009, 19:29
Count me in...
01. alexg
02. whippit
03. Jimmer
04. martin_bailey_1
05. Max and Andy
06. Andy_J
07. Alan (ab2cv)
08. BFG in the BRG
09. Ben (vi11ain)
10. Exbury
11. CJ
12. BigErch + Brakes (HiSpek 275 on the front)
BigErch
Postby bobbrown » Mon 20.04.2009, 19:44
Due to demand I am going to do another run on the rears but as they require the hub conversion to fit them have decided to include them in this list that way I can see that people have the hubs and it will save me bouncing between lists.
So to that end if you want to add the rear conversion to the hubs just stick + brakes on the end and I will work it out from there.
When the time comes I will require some additional information like wheel size and type of disc etc but we can come to that later.
One thing to note the rear brake upgrade can only be done if the fronts have been upgraded or are being upgraded at the same time, I will not supply anyone who’s fronts are not suitable.
Bob
Pacific Blue N/A
bobbrown
Re: Re:
Postby ab2cv » Mon 20.04.2009, 19:57
01. alexg
02. whippit
03. Jimmer
04. martin_bailey_1
05. Max and Andy
06. Andy_J
07. Alan (ab2cv) + Brakes (front upgrade in the pipeline!)
08. BFG in the BRG
09. Ben (vi11ain)
10. Exbury
11. CJ
12. BigErch
Thanks Bob 8)
Yellow Esprit GT3
ab2cv
Re:
Postby CJ101KT » Mon 20.04.2009, 21:14
01. alexg
02. whippit
03. Jimmer
04. martin_bailey_1
05. Max and Andy
06. Andy_J
08. BFG in the BRG
09. Ben (vi11ain)
10. Exbury
11. CJ + Brakes (Wilwood 16" front upgrade)
12. BigErch
CJ101KT
Postby vi11ain » Mon 20.04.2009, 21:21
01. alexg
02. whippit
03. Jimmer
04. martin_bailey_1
05. Max and Andy
06. Andy_J
08. BFG in the BRG
09. Ben (vi11ain) + Brakes
10. Exbury
...of the plot
vi11ain
Postby Turners » Tue 21.04.2009, 23:11
vi11ain wrote:01. alexg
02. whippit
03. Jimmer
04. martin_bailey_1
05. Max and Andy
06. Andy_J
08. BFG in the BRG
10. Exbury
13.Turners
Turners
Postby bobbrown » Tue 21.04.2009, 23:41
01. alexg
02. whippit
03. Jimmer
04. martin_bailey_1
05. Max and Andy
06. Andy_J
08. BFG in the BRG
10. Exbury
13.Turners
Pacific Blue N/A
bobbrown
Postby alexg » Wed 22.04.2009, 10:48
01. alexg + Brakes (Front and Rear)
02. whippit
03. Jimmer
04. martin_bailey_1
05. Max and Andy
06. Andy_J
08. BFG in the BRG
10. Exbury
13.Turners
alexg
Postby surfboardfiller » Thu 30.04.2009, 00:07
02. whippit
03. Jimmer
04. martin_bailey_1
05. Max and Andy
06. Andy_J
08. BFG in the BRG
10. Exbury
13.Turners
14. Phil
Can I get my 2nd pair, I only got one of the two pairs last time
surfboardfiller
Postby texas2201 » Thu 30.04.2009, 10:05
[quote="surferphil"]01. alexg + Brakes (Front and Rear)
02. whippit
03. Jimmer
04. martin_bailey_1
05. Max and Andy
06. Andy_J
08. BFG in the BRG
10. Exbury
13.Turners
14. Phil
15. texas2201
