Aluminum Door Pulls and Handles - Who's Interested
Postby F1 LOTUS » Mon 26.05.2008, 01:55
Sorry I haven't been around to interject (been Tom & Dick - ok now :D )
I'll get into the design / costing of the release levers in the coming week so we'll have a cost for the complete package...
F1 LOTUS
Postby jecuk » Mon 09.06.2008, 23:02
1. Elanlover (fancy pulls + handles)
2. theelanman (pulls + handles)
3. Ailwyn (fancy pulls + handles)
4. Ailwyn (fancy pulls + handles)
5. Breitlingthx (fancy pulls + handles)
6. F1 LOTUS (fancy pulls + handles)
7. rip (fancy pulls + handles)
8. jecuk (normal handles and pulls)
jecuk
Re: Aluminum Door Pulls and Handles - Who's Interested
Postby rip » Fri 01.05.2009, 13:40
Forgotten project???
Postby Elanlover » Fri 01.05.2009, 13:51
rip wrote:Forgotten project???
Yes and no. With Brian selling his Elan I don't think he'll be up for too many projects. But, I was just thinking about this project this very morning so your post couldn't be at a better time. I will send Brian an e-mail to see if he is still interested in working on the project. If not, I will contact a local machine shop to see if they can quote on it. I'll update this thread when I get some answers.
Postby rip » Fri 01.05.2009, 17:14
Nice one, Blair. :smt023
Re:
Postby esprit888 » Fri 01.05.2009, 17:37
9. esprit888 (fancy pulls + handles)
esprit888
Postby F1 LOTUS » Sat 02.05.2009, 07:40
:D :D :D ... :oops:
I have a bit of a window just now and would like to see if I can push the project through to completion :D
As I recall I had the preliminary modeling done prior to receiving a sample of the stock item - the door pull needed some tweaking, the release lever I think still had some modeling to do?
Let's see what can be done...
F1 LOTUS
Postby Elanlover » Sat 02.05.2009, 13:56
Thanks for looking into this again Brian. Its very kind considering you're currently Elan-less.
Postby theelanman » Sun 03.05.2009, 01:25
Postby F1 LOTUS » Wed 20.05.2009, 07:51
Door Pulls are out for machining quote now - hopefully the shops are hungry :twisted:
F1 LOTUS
Postby rip » Wed 20.05.2009, 08:54
:smt023
Re: Re:
Postby Elanlover » Wed 20.05.2009, 13:13
I'm changing my request to normal pulls and handles if possible Brian. Thanks.
1. Elanlover (normal pulls + handles)
Postby F1 LOTUS » Tue 07.07.2009, 23:47
FYI
I'm still persevering with this, trying to get some machining costs. I've made a quick prototype to check the fit in an actual door panel, this showed some minor tweaks were required. Also, I think we would have to go with one design only to give us a chance of reasonable costs for such a low quantity - so I revised the design to hopefully appeal to most people...?
F1 LOTUS
Postby esprit888 » Wed 08.07.2009, 04:56
Looks great, where do i send the money ? :lol:
F1 LOTUS wrote:FYI
esprit888
Postby rip » Wed 08.07.2009, 08:50
I like that too.
Postby Elanlover » Wed 08.07.2009, 13:11
Brian, as ususal your design looks great. I'd be happy with that. The only thing I'd ask about would be this. Did you ever consider (in any of your designs) "thinning" the pull? The reason I ask is that I've always found it hard to slip my hand in behind the pull. I can certainly do it but I've always thought that if the pull was just a little bit thinner it would be easier to get my hand in there. Just a thought.
Are you also still looking into the handle as well?
Postby F1 LOTUS » Wed 08.07.2009, 21:50
Elanlover wrote:Brian, as ususal your design looks great. I'd be happy with that. The only thing I'd ask about would be this. Did you ever consider (in any of your designs) "thinning" the pull? The reason I ask is that I've always found it hard to slip my hand in behind the pull. I can certainly do it but I've always thought that if the pull was just a little bit thinner it would be easier to get my hand in there. Just a thought.
The Door Pulls will be thinner in aluminum, for the very reason you've mentioned :D
Costs - Initial machining costs indicate a PAIR of Door Pulls will likely be just under $200? Based on producing 20 pairs.
How does that fit with peoples budgets???
F1 LOTUS
Postby rip » Thu 09.07.2009, 00:54
Similar to what was originally estimated, so ok with me.
Postby esprit888 » Thu 09.07.2009, 03:20
Sounds great, where do i send the money ? :D
esprit888
Postby F1 LOTUS » Thu 09.07.2009, 05:57
Sounds good :D
If everything goes well with the Door Pulls, it shouldn't be a problem to follow-up with the door-release handles - they're smaller but more complex to machine, I'll get the Pulls finalized then get the release handles out for quote ASAP.
Apparently the release handles are from a Carlton / Senator?? Maybe a blingy alternate already exists???
F1 LOTUS
Return to Interior
