hoop advice please
hoop advice please
Postby mvf906 » Tue 12.05.2009, 12:36
hi all, I am thinking of having some of simon's hoops fitted but without changing the deck etc.
Has anyone done this without adjusting the deck ? It looks a tight fit from the pics.
me in my head, shifting & drifting, mechanical music, adrenaline surge
mvf906
Re: hoop advice please
Postby Elanlover » Tue 12.05.2009, 13:29
Pretty sure that there's no need to adjust the lid. Its a tight fit but I think its not a problem. Best to PM Simon himself.
Postby Nige » Tue 12.05.2009, 14:46
Simons hoops will fit with a standard rear deck in place. If the rear deck is adjusted to fit on the car correctly then there will be sufficient clearance with the hoops. See the group buy thread for photos of this set up on Monty's car Here.
Back in Blighty
Nige
Postby Monty » Tue 12.05.2009, 19:55
No isuses with the Hood deck with Simons roll hoops
Postby mvf906 » Wed 13.05.2009, 11:01
thanks for the help and link, how do I add a name to the list :?:
mvf906
Postby paulwatkins » Thu 14.05.2009, 13:41
mvf906 wrote:thanks for the help and link, how do I add a name to the list :?:
I've taken the liberty of adding your name to the list that Nige pointed you to previously. I've also assumed you would want them fitted by Simon. If not, please just post up and someone will remove it
paulwatkins
Postby mvf906 » Thu 14.05.2009, 18:26
thanks paul :D
mvf906
