Erm................ sorry about this, but how does the front of the dash come off?[/quote]
I wouldn't do that - - that seems a lot of work.
I've got a similar problem to investigate - mine only blows into the foot-wells so the windscreen mists up. I'm going in through the hole left by taking out the radio, which I'm changing anyway - so much quicker and easier. Radio is secured at the rear by a nut you get at first by removing the glove box. Move the catch sideways so it swings right down and remove the hinge pins if you wish for a bit more room to move. Reach in there and round to the back of the radio to undo the nut. Once the radio is out most of what you need to see & get at for heater vent system is right there!
I'll look for a perished piece of rubber!
