Still no luck getting elanscan to work
Postby chrishewett » Thu 04.06.2009, 08:04
Now I have got my car back from the garage I am trying again to get elanscan to work.
I have tried using both usb ports.
On comm port 1 I get:-
Error log Bad echo received Sent F4 56 01 B5
On comm port 4 I get:-
Comm port inactive No frame start byte received Bad echo sent F4 56 01 B5
I have downloaded the driver and windows says all is working. I have set the valence to 1. Windows XP.
Any help would be appreciated.
chrishewett
Re: Still no luck getting elanscan to work
Postby CJ101KT » Thu 04.06.2009, 11:07
Have you tried cycling through the COMM Ports within Elanscan with the car runnning or do non of them return a signal? May be worth removing the installed driver and repeating the process from start as the order in which things are done can sometimes affect it?
CJ101KT
Postby chrishewett » Thu 04.06.2009, 22:44
I have been ticked off for starting a new thread on this subject so a big sorry for that.
I must remember that this is not lotuselan.net!
chrishewett
Return to ElanScan
