by bobbrown » Mon 22.06.2009, 22:07
It is something I have been thinking about and I do not have a problem ordering some more.
You can use the standard cables and I will supply a spacer for those but it is a more elegant solution to change the cables particularly if your existing ones are getting a little past their best. They seem prone to rust around the area they fit to the calipers.
pic of spacer c/o Nige
- handbrake cables.jpg (55.38 KiB) Viewed 3791 times
Pacific Blue N/A
bobbrown
by mnemonix » Mon 22.06.2009, 22:18
Thanks Bob, as fate would have it, my car's due its MOT tomorrow and the handbrake's definitely a fail. I tried adjusting it with no success, so I'll see what Peter Smith says tomorrow. If I have to have new cables I'll be stuck with a set of new standard ones, if it just needs a bleed, then I'll be be up for a set of yours suitable for the hispec upgrade when it arrives...
mnemonix
by bobbrown » Mon 22.06.2009, 22:39
When you say the handbrake is a fail it is probably not cable related but more likely the calipers themselves, the easy check is to disconnect the cables and if they move freely then it’s not those at fault.
If the hand brake is not working correctly and the lever is on its back stop the cable should only be adjusted to take the slack out of the cable, it can not be adjusted to make the handbrake work. One thing to try/check, make sure the lever is on its back stop and then apply the handbrake a few times, I have done this while also pressing the foot brake really hard and the hand brake has come back all be it still not brilliant, 6 clicks instead of 7 / 8. The new Hi spec calipers are 2 clicks.
Bob
Pacific Blue N/A
bobbrown
by markv » Wed 24.06.2009, 20:07
Hi Bob
I just wondered whether the cables were available now? When I met up with you at Donington they hadn't yet arrived.
by bobbrown » Wed 24.06.2009, 21:24
Handbrake cables are here awaiting delivery, some have gone out with the rear brake upgrade so it is just the ones for the standard calipers.
If you are in the list for the new hubs they will ship with those just need to sort out the lists.
If you are just after the cables PM or email your address and I will get them sent in the post.
Bob
Pacific Blue N/A
bobbrown
by markv » Thu 27.08.2009, 01:33
Ho Bob
I wondered whether you'd got my email as I haven't received the cables yet?
by bobbrown » Thu 27.08.2009, 11:56
Sorry for the delay will get them off to you tomorrow
too busy, to much to do so little time in a day.
Bob
Pacific Blue N/A
bobbrown
by markv » Thu 27.08.2009, 12:27
Thanks Bob. I know that feeling too!
by markv » Tue 08.09.2009, 22:54
Just to confirm that I've received the cables - they look good! Thanks once again.
by Gazza » Tue 12.01.2010, 15:47
Anybody else fitted these? Seem to work very well with the brake upgrade but need to be a Russian weight lifter to get the handbrake to the first click.
Cheers, Gazza
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
by bobbrown » Wed 13.01.2010, 12:04
Gazza wrote:Anybody else fitted these? Seem to work very well with the brake upgrade but need to be a Russian weight lifter to get the handbrake to the first click.
Cheers, Gazza
This seems to be an issue with some cars due to a change in the handbrake lever design and the later S2 handbrake levers e.g. the ratchet starts further up the lever movement.
If you crimp the eye in the handbrake lever slightly, just enough so the cable can not come out and place a small amount of slack in the cable the hand brake should work better.
Bob
Pacific Blue N/A
bobbrown
