stevieshag wrote:I have a belkin 54g wireless router which i want to eventually want to use it for my laptop & my xbox 360.
I have tried to connect to the router but it doesnt connect,
the instructions basically explain it as a plug n play, i just wish this was the case.
i have tried connecting via the ethernet cable aswell but no joy, my isp is virgin.
Help !!! any suggestions.
stevie
Doug wrote:Yes, you have to configure it with the component connected to it via ethernet cable, then you can unplug and roam . . .
Gary wrote:You need filters on EVERY socket that has something connected - from your diagram it looks like you have.
markv wrote:I work for an ISP and have suffered a number of the problems described. Here are my recommendations:-
1. Put a microfilter in EVERY phone socket/extension. Go for good quality filters - I was given two by my ISP and had loads of trouble similar to you (broadband dropping every time we used the phone or someone rang). I went for the XF-1e Professional ADSL Microfilter from adslnation here . At £7.99 each they are not cheap, but the difference was immediate (no line drops and faster speed immediately).
2. Plug your router into the master socket microfilter. Make sure you have a decent quality router (I use a Netgear DG834G myself).
3. Buy and install an I-PLate in the master socket (If your socket is compatible - 95% are). This is a BT produced, widely available, user installable add-on which isolates the main socket from almost all the noise produced by the extension wiring (and if you have multiple extensions, you'll probably have a lot of noise). It took me 10 minutes to install the I-Plate into my master socket and I immediately got 3Mb faster download speeds and much improved reliability. See here for the I-Plate and here to check whether your master socket is compatible.
4. Go for an ISP with a track record. I use virgin.net, which offers up to 20Mb adsl in many areas of the country.
After doing all the above, my adsl speed increased from 2.5Mb to almost 8Mb. Every line is different though - although phone extension wiring is a major factor, so is distance from your exchange and quality of the BT copper wires from the exchange to your home.
Return to Computer Help / IT Area
