Rubber lip - clamping plates **CLOSED**
Re: Rubber lip - clamping plates **CLOSED**
Postby nickb » Mon 22.06.2009, 14:05
Yes please Paul forgot to add that bit on.
How do go about paying?
nickb
Postby paulwatkins » Mon 22.06.2009, 20:30
1, paulwatkins
2, Enright (+S/S fixings) - paid
3, esprit888 (+S/S fixings +p&p CANADA)- paid
4, Specky (+S/S fixings)
5, Specky (+S/S fixings)
6, Dave Eds (+S/S fixings) - paid
7, Nige (+p&p) - paid
8, Nige (+p&p) - paid
9, GeoffSmith - paid
10, Mnemonix (+ S/S fixings +p&p UK) - paid
11, Dico (+S/S fixings +p&p UK) - paid
12, martin_bailey_1 (+S/S fixings +p&p UK)(include garywbrooks) - paid
13, Router (+S/S fixings +p&p UK) - paid
14, nitroman (+p&p USA) - paid
15. Richard K (+p&p UK) - paid
16, pinky - paid
17, pinky - paid
18. BFG in the BRG (+S/S Fixings +p&p UK) - paid
19. Woody in the BRG(+S/S Fixings) - paid
20, mini55(+S/S Fixings +p&p USA) - paid
21. Jimmer (+S/S Fixings +p&p UK) - paid
22. Matt RI (+p&p USA) - paid
23. Gazza (+S/S Fixings) - paid
24. alexg (+S/S fixings +p&p UK) - paid
25. Max and Andy (+S/S fixings) - paid
26. G UK (+S/S fixings) - paid
27.Blacknight - paid
28. Breed (+S/S fixings +p&p UK) - paid
29. Nobby (+S/S fixings) - paid
30. MPx (+S/S fixings) - paid
31. JimF (+S/S fixings +p&p UK) - paid
32. garywbrooks (+S/S fixings)(please send with Martin's) - paid
33. saska (+S/S fixings +p&p UK) - paid
34. Exbury (+p&p UK) - paid
35. superbad (+S/S fixings +p&p USA) - paid
36. mvf906 (+S/S fixings +p&p UK) - paid
37. Nickydee (+S/S fixings +p&p) - paid
38. markv (+S/S fixings) - paid
39. Davey_B (+s/s fixings + p&p) - paid
40. nickb (+s/s fixings + p&p)
Nick PM sent with payment details.
paulwatkins
Postby nickb » Wed 24.06.2009, 11:21
Thanks Paul, money was transfered last night.
nickb
Postby paulwatkins » Wed 24.06.2009, 18:48
1, paulwatkins
4, Specky (+S/S fixings) - paid
5, Specky (+S/S fixings) - paid
16, pinky - paid
17, pinky - paid
40. nickb (+s/s fixings + p&p) - paid
I'm going to be starting to send these out soon. Please be patient - spare time is at a bit of a premium at the moment. It may take me a while to get around to them all.
paulwatkins
Postby BFG in the BRG » Tue 30.06.2009, 12:25
Many thanks for sorting this out the parts look the biz - looking forward to fitting - done the hard bit and took the old one off ages ago :-D - it involved a Dremmel with a grinding wheel, old cleaner pump-spray filled with water and a pair of mole grips - ooh and a screwdriver to remove the odd non-corroded one :roll:
1, paulwatkins
16, pinky - paid
17, pinky - paid
18. BFG in the BRG (+S/S Fixings +p&p UK) - paid - Received
Alas soon to be Elan-less
BFG in the BRG
Postby Jackonicko » Tue 30.06.2009, 22:57
If anyone drops out, or decides against, I have a sudden need that I didn't know I had.
Yeah, yeah, I know........
......... but this hasn't been an easy month.
Jackonicko
Postby Specky » Wed 01.07.2009, 12:45
Many thanks Paul,
1, paulwatkins
4, Specky (+S/S fixings) Collected
5, Specky (+S/S fixings) Collected
16, pinky - paid
17, pinky - paid
Postby alexg » Tue 14.07.2009, 12:48
All recieved, thanks very much for your efforts
1, paulwatkins
16, pinky - paid
17, pinky - paid
24. alexg (+S/S fixings +p&p UK) - paid & recieved
alexg
Postby BFG in the BRG » Tue 14.07.2009, 13:50
Many thanks Paul for sorting this out.
Fitted them a few days ago - pretty straightforward - fiddley more than anything - great piece of kit and the BFG looks so much better - I managed to use the larger size spire clips all the way round - the 4 thin ones supplied looked like they may be a bit more fiddley to get in place since they will be a tighter fit. For what it's worth.....just incase anyone wants instructions.
To remove the old lip - took me around 2 hours, to fit the new lip and clamping plated - about another hour
Tools I used to get the job done
Penetrating oil
Jack and axle stands/long low ramps
Philips Screwdriver
Small flat bladed screwdriver
Large flat bladed screwdriver
Preferably a battery operated screwdriver/drill
Dremmel with Grey grinding wheels - the pink ones are too soft
Water spray - a bathroom/kitchen cleaner spray pump bottle will do
Eye protection
Mole grips
pliers
Stanley knife
disposable PVC gloves (optional) - available from screwfix et al - saves you getting too messy and helps prevent cuts and grazes.
Replacement rubber lip - available from walkers rubber - details earlier in this thread
Copious amounts of tea
When I saw the advert I always thought a Dremmel was a bit of a poncy tool - however I have found it to be superb for Lotus work since the attachments are relatively gentle and with a flexible shaft - really good for awkward places, and if using water - less risk of electrocution. If you go to B & Q and get their own range tool it is really cheap £30 ish) and comes with a load of attachments - including the grinding wheels - the only downside is that it burns out pretty fast - I've got through 3 of them and never had a problem getting them replaced by B & Q, though in the end I preferred to get a proper Dremmel since having to down tools and return to B & Q was a pain.
Method
At least a day before - spray all the screws liberally with the penetrating oil - the more screws you can unscrew rather than grind off the better - I managed about half.
1) Raise the front of the car up
2) Use the screwdriver to remove what ever screws you are able.
3) grind the heads off of the screws that are too badly corroded - ensuring you keep everything cool by stopping grinding and spraying with water - I often don't use safetyglasses - I find they can obscure vision - but on this occasion they are a must- this is a messy job with lots of grot flying around
4) grip the remainder of the screw with the molegrips/plier and twist off
5) Take the small flat bladed screwdriver and push it through the hole where the screw went and push gently against the top of the old clip so that it spreads it apart - you should now be able to remove the old spire clip
6) there's a large rubber bung under each front corner - just twist and pull - it gives access to a couple of the spire clips in the corners
7) take the new spire clips, grip them with the mole grips and splay the clip slightly with the large flat bladed screwdriver so it doesn't grip quite as tightly on the fibreglass - I aimed for a gap of around 2/3 mm - otherwise I found it almost impossible to get the clips on because the fibreglass is quite thick.
8 ) there are 2 sizes of screws supplied - the 4 narrower screws go with the thinner spire clips.
9) once all spire clips are in place, offer up each section of the clamp plate to check the holes are in the right place - mine were - no problems.
10) Take the new rubber lip - ensuring there is overhang of around an inch at the wheel arch, I started using one of the corner clamping plates than worked my way round - I guess I could have marked the rubber lip half way and done the same with the middle section of the clamping plate and simply matched up the marks - it would probably have made the job a bit easier.
11) I found it easier to use one of the middle holes in the clamping plate to start off - trying to do one end makes means the plate is difficult to hold in place since the weight of the plate is pulling it down - also there is a risk that the weight of the plate hanging on one screw fitted to the end will rip the fibreglass - whereas in the middle everything is more balanced - ensure your electric screwdriver is set to its lowest tightness setting (torque) - otherwise you'll bugger up the spire clip
12) when all the screws are in place, trim off the ends with a stanley knife
13) step back and admire your work
14) Go for a test drive - you need a reward
BFG in the BRG
Postby theelanman » Tue 14.07.2009, 18:51
glad to hear the digital doodle I did wasnt any different than Dee's original......
paul and I were worried it may have stretched in 'transfering' it over......
nice work paul...
good call dee....
and a big pat on the back to everyone.....(Im guessing paul would have been having kittens trying to sirt this 'huge' buy out) :-D
Postby Nige » Tue 14.07.2009, 20:15
Paul, I'm a bit slow in saying thanks for this, my 2 sets arrived safely last week and have been added to the parts mountain and jobs to do list.
Many thanks indeed.
Back in Blighty
Nige
Postby Breed » Tue 14.07.2009, 20:36
Thanks Paul
Plates and fixings arrived safe and sound.
Bill
Breed
Postby nickb » Fri 17.07.2009, 12:57
Thanks Paul, all arived safely last week.
Thanks again
nickb
Postby esprit888 » Sun 19.07.2009, 20:45
Recieved mine on Friday Paul , thanks for all your efforts in putting this group buy together, now where can i buy the time to fit them :lol:
Colin
esprit888
1, paulwatkins
16, pinky - paid
17, pinky - paid
40. nickb (+s/s fixings + p&p) - paid[/quote]
esprit888
Postby Gazza » Thu 23.07.2009, 17:48
Paul
Did you post all of them at the same time as I was away last week and have not received mine yet?
No rush, just curious.
Gazza
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
Postby paulwatkins » Fri 24.07.2009, 13:27
Gazza wrote:Paul
Gazza
I thought you wanted me to hang to yours! :lol:
If you want them posted, please PM me your address and send the postage cost over.
Cheers, Paul
paulwatkins
Postby Gazza » Fri 24.07.2009, 17:35
Paul
Sorry mate I couldn't remember what I said because it's taken you so long to sort this out :wink:
I'm getting confused with the wheel arch liner group buy you are doing as well, don't even remember sticking my name down for that :oops:
Hang onto both and will get them off you sometime, like I said no rush :D Await your PM for the payment details for liner.
Cheers, Gazza (p.s battery charger is still the best thing I have bought :lol: )
SOLD
Gazza
Postby Dave Eds » Fri 24.07.2009, 17:53
Gaz - if you decide want to fit them sooner you can have mine and I'll get yours of Paul at next years I.O.M. :wink:
C.O.Y.S.
Postby GeoffSmith » Fri 24.07.2009, 20:09
Dave Eds wrote:Gaz - if you decide want to fit them sooner you can have mine and I'll get yours of Paul at next years I.O.M. :wink:
:lol:
F.O.Y.Y.B.
Postby Dave Eds » Fri 24.07.2009, 20:20
:lol:
F.O.YPremier League.Y.B.
