tigerdog wrote:Despite reading this entire thread and the wiki, a few of us are still faced with a problem: many of the oils loved and recommended here are simply not available on the left side of the Atlantic. Specifically, Castrol Edge is only available in 5W-30 and 10W-30. The magic 10W-60 and even the more common 5W-40s aren't commonly available here. One exception is a German full-synthetic called "Lubro-Moly". The BMW boys drool all over the stuff and it's readily available in a 5W-40. Mobil 1 0W-40 can be had in a few places but I have the same experience as others here; the engine is noisier and the idle oil pressure is somewhat low for my comfort. So - anyone here have experience with the lubro-moly full synth or am I about to embark on an experiment?
nitroman wrote: I've just read a long article on oil. The recommendation is to pick a better oil, but don't change from the recommended viscosity.
Elanlover wrote:nitroman wrote: I've never met anyone who lives in Averagetown, USA yet.
I think San Fran would be about as consistently average as one can get (does it ever deviate from 75F there????? stevieg8571 wrote:After reading the above posts I'm now having second thoughts about my next oil change (which will be done same time as the R/H driveshaft's changed)
I was going to use Mobil 1 15W 50 that I already have and a K&N filter but now think it may be too thick for British temps, especially as what little warm weather we had is about to finish. I could easily get some Mobil 1 10W 40 instead as I think this would be more suitable.
Any thoughts?
nitroman wrote:different weight oils
rip wrote:nitroman wrote:different weight oils
I've seen this phrase used a lot. If you want to inrease your oil's weight, stick some more in & gravity will have more to pull against![]()
Fluid thickness is viscosity, not weight.
) - whatever the viscosity was when it was made. In other words, oil is only one viscosity. Its the polymer additives that allow manufacturers to create a 10W40 oil. That's an oil that "acts" like a 10W when cold and a 40 when hot. Ideally you'd want an oil that has as small a spread as possible. If you could run a straight 30 in the car you would beacause it would have no additives and behave exactly as a perfect 30 weight should. Just because the additives let an oil "act" like a thinner or thicker oil doesn't mean it IS thinner or thicker. But, the additives help with cold starts and cold outside temps that a 30 might not be as good at while adding high temp protection that a 30 can deliver.
Could be some do it differently which would be good to know. If you lived in a hot climate then an oil based on 40 with additives to help at lower temps and cold starts would be ideal. In cold climates the opposite would be better.Elanlover wrote:If you could run a straight 30 in the car you would beacause it would have no additives and behave exactly as a perfect 30 weight should.
Elanlover wrote:
I wish I could remember if companies start with a 40
RayD wrote:Elanlover wrote:If you could run a straight 30 in the car you would beacause it would have no additives and behave exactly as a perfect 30 weight should.
Blair, you would be able to .... SAE30 is the one you would associate with car engines, in normal conditions.Elanlover wrote:
I imagine it is a 30 for the same reason as above.
Ray
And that's for all the reasons mentioned above (cold starts, cold climates, etc.). That's why we have multi weight (or multigrade) oils for cars. Most single weight oils are used in industrial settigns for equipment, etc. that's run indoors where the climate is somewhat controlled (and also in non internal combustion engine applications) and some diesel applications.Elanlover wrote:If you could run a straight 30 in the car you would I'm not sure about the SAE 30 starting point. There's only so mush a guy can remember after 25 years. But, I've a hunch that its the lower weight (the winter weight) number that's the starting point. The polymers are bunched up at colder temps so the oil flows quickly but expand when warmer "slowing" oil flow so it acts like a heavier oil would.
