tonny006 wrote:I have recently fitted an Everest chip which is working perfectly on the road.
Doing a trackday yesterday i had a cooling issue (which i need to sort out),where the temperature is going up too high.
After 1 lap the temperature was above halfway on the guage and the boost reduced it's self back to standard.
Is this what it should do,when i sort out the cooling will it work properly .
After getting stuck in a traffic jam today i had the same problem untill it cooled down.
tonny006 wrote:After 1 lap the temperature was above halfway on the guage and the boost reduced it's self back to standard.
Elanlover wrote:tonny006 wrote:After 1 lap the temperature was above halfway on the guage and the boost reduced it's self back to standard.
Just reading this again - the needle on the water temp guage will regularly move between 1/4 and 3/4 on the gauge. This is normal operation for the car as the fans don't kick in until the 3/4 mark is reached. If this is what you're seeing its normal. If its something other than this please describe it.
The car has to get very hot before the boost is limited by the ECU. If you're seeing the boost gauge showing only .6 bar that could be completely unrelated to the engine temp. The gauge is notoriously inaccurate, wastegate could be sticking open occassionaly, the ambient air temp could be too warm to get a higher boost pressure, you may have a leak in the inductions somewhere that gets worse when the engine bay gets hot, etc.
tonny006 wrote:Sorry for not being clear.
I know the fans always kick in at 3/4.
On the track as i set off,the guage was about 1/4 and was steadily rising to 1/2 by the end of the first lap, and by the end of lap 4 it was at the 3/4 mark which as we know is very hot.
each lap is nearly 4 miles.
tonny006 wrote:Let the fan cut in and i have Just taken it for a thrashing,
Here is the Elanscan result
tony1.ecu
OOPS it didn't work.
How do i post it?
