Compatible with Windows CE?
Postby Jackonicko » Thu 20.08.2009, 16:36
Does Elanscan run on Windows CE (as used by some netbooks?)
Jackonicko
Re: Compatible with Windows CE?
Postby ailwyn » Thu 20.08.2009, 17:04
No, windows 95/98/2000/xp/vista only
ailwyn
Postby Jackonicko » Thu 17.09.2009, 17:36
Thanks, Ailwyn.
What a nuisance!
Jackonicko
Re: Compatible with Windows 7?
Postby kmckmc » Thu 12.08.2010, 02:54
How about Windows 7?
Elan M100 S2
kmckmc
Postby rip » Thu 12.08.2010, 09:08
kmckmc wrote:How about Windows 7?
:smt023
That's what I currently run it on.
Postby saska » Thu 12.08.2010, 12:44
Oooh interesting: 32bit or 64bit?
Tony
adw (at) saska.co.uk
saska
Postby dapinky » Thu 12.08.2010, 14:04
I can run it on 32bit W7 Ultimate, and 64bit - both on straight W7, not virtual XP.
Postby saska » Thu 12.08.2010, 16:37
dapinky wrote:I can run it on 32bit W7 Ultimate, and 64bit - both on straight W7, not virtual XP.
OK Ta. That means it doesn't have any 16bit components otherwise it wouldn't play nice on 64bit
Can you also log .ecu files on 64bit AKA do the USB/Serial drivers work on 64bit?
Tony
saska
Postby dapinky » Thu 12.08.2010, 17:22
Tony,
That's a good question which i can't answer!
My IBM was the machine that I put the 64 bit version on, and the Dell has 32 bit - i found that the IBM wouldn't really work well with it (not enough RAM) so set it back to XP for the kids to use......
Certainly, the 32 bit will do everything that XP would (in regards to Elanscan .ecu files).
Don't know if it helps, but the Dell came with 64 bit Vista, but i junked that when i went to W7, and only had a 32 bit version to install - can't remember if i actually used the 64 bit version with elanscan, or if i was still on the IBM at that time......
Postby GeoffSmith » Thu 12.08.2010, 18:49
ES was coded in Delphi. Alan is thinking of re-writing it in e.g. FPK which can be compiled for many platforms. The interface USB drivers are universally supportive.
Postby saska » Thu 12.08.2010, 19:30
GeoffSmith wrote:ES was coded in Delphi. Alan is thinking of re-writing it in e.g. FPK which can be compiled for many platforms.
FPK would be a good call as there are good Delphi resources and it would work on Linux, FreeBSD, Mac, Win32/64 as well as maybe MacOS/Arm (think iPhone) and 64bit Mac OSX
Yes. I had a look at http://www.ftdichip.com/Drivers/VCP.htm which is where I got drivers for my USB cable when the Elanscan ones wouldn't play with the Thinkpad.
Out of interest which FTDI chip is in the cables?
Tony
saska
Postby GeoffSmith » Thu 12.08.2010, 20:39
232R
Return to ElanScan
