door panel 'scrivets' - cheaper alternatives
Postby scottswatches » Mon 03.08.2009, 13:35
There are seven plastic scrivets (screws + rivets for the hard of thinking) on each door panel, and when i had to drill them out i got a shock from Lotus that they cost £1.89 each plus vat. Being tight and not wanting to pay £24 to replace these i found perfectly servicalbe items from Halfords at £2.49 for 8. Eventually, something cheap in halfords!
Scott.
Do I buy another Elan or go for something older and different?
scottswatches
Re: door panel 'scrivets' - cheaper alternatives
Postby inkitin » Mon 03.08.2009, 18:09
Hi Scott
Do you have a bit more information as to whereabouts in Halfords, as I will also be going into my Elan doors soon?
Roland
91 SE Calypso Red
inkitin
Postby RJ2001 » Fri 18.09.2009, 18:08
Thats great news scott...More information would be great as i too will be taking my door to pieces!!
Great Find! RJ
RJ2001
Postby John_W » Fri 18.09.2009, 22:48
Might be these.
However, on my door, most of the plastic panels are fixed using much smaller plastic rivets which have an un-threaded centre part which you just push out and find inside the door later, like this.
Postby inkitin » Fri 18.09.2009, 22:53
Excellent.
Thanks John.
91 SE Calypso Red
inkitin
Postby GeoffSmith » Sat 19.09.2009, 10:23
Here's another one with prices if you fancy a group buy! :twisted:
Postby theelanman » Sat 19.09.2009, 18:45
Postby GeoffSmith » Sat 19.09.2009, 19:31
Return to Doors and Windows
