LGM Turbo Group Buy - Start Shipping Out Yeah
Re: LGM Turbo Group Buy - Start Shipping Out Yeah
Postby GeoffSmith » Sun 11.10.2009, 20:18
Postby RichardK » Sun 11.10.2009, 21:08
Lotus 001Bits left over.jpg (97.54 KiB) Viewed 62344 times
Trying to post pictures.....
Note the shiney sheared bolts in the pre cat and the almost but not quite intact turbo studs
[Edit.....It Worked!!!]
RichardK
Postby RichardK » Sun 11.10.2009, 21:17
Finished
Lotus 002Finished.jpg (81.07 KiB) Viewed 62341 times
Close Up..not all heatshields installed
Lotus 010Closer.jpg (81.95 KiB) Viewed 62341 times
Lotus 003THE BOV.jpg (73.5 KiB) Viewed 62341 times
Upgrade session also included replacing the fans(thanks Gordon), addition of O2 sensor and closed loop programs through a V5 switcher, 15" to 16" brake upgrade with Hispec Rears, Bob's rear hub upgrade ( thanks Bob) new handbrake cables and added the pneumatic silencer to the BOV.
Still to do:
550cc Injectors
3bar Map
boost controller ( upgrading the mark I right foot)
And they opened Chapmans Peak Drive yesterday: Click on this - http://www.chapmanspeakdrive.co.za/ - I live at the bottom of this drive. Toll went up to 28Rands ( £2) :cry:
Fantastic!!
RichardK
Postby Dico » Sun 11.10.2009, 21:33
Nice work Richard.
Hoping to get mine sorted real soon. 550 injectors need ordering next. Haltech maybe, hmm?
Postby Dico » Mon 12.10.2009, 01:57
I pinched this link from Tony's thread. Are these the correct ones anyone know?
Blimey thats a fair ammount of dollars, especialy with the exchange rate as it is. Available anywhere in the UK do we know?
http://www.rceng.com/Peak-Hold-Injector ... P15C5.aspx
Postby CRAMBURY RS » Mon 12.10.2009, 04:03
richardk, looks awesome !!! have you had a chance to drive it since the install? even at a stock boost limit, it's ear to ear grinz :D
CRAMBURY RS
Postby Monty » Mon 12.10.2009, 13:15
Richard,
Hows the car running on the stock injectors and Mountain chip?
Postby lotusgirlmarie » Mon 12.10.2009, 18:21
Good job!!! Just one minor tidbit. The turbo heatsheild mount needs to be moved back to the bolthole nearest the manifold roughly at the 10 o'clock position. This will give a better look and functionality. The angle cut in the front of the shield matches that of the bodywork. Don't forget to leave space in between the turbine housing, the shield and all associated bodywork. Good job again!!! Bravo!!! What do you think?
lotusgirlmarie
Goddess
Postby CRAMBURY RS » Mon 12.10.2009, 19:36
i'm curious, is anyone header wrapping the downpipe? i know it's the not the most beautiful thing, but it sure does keep that heat down.
fyi, that's DEI header wrap (they make a TITANIUM wrap as well), EGT, wideband bung and v-band. thank you luv (LGM) for the DP parts and getting it started, you're my lil car angel :wink:
CRAMBURY RS
Postby Monty » Mon 12.10.2009, 20:02
Our LGM custom pipes have been ceramic coated :wink:
Postby CRAMBURY RS » Wed 14.10.2009, 22:52
Monty wrote:Our LGM custom pipes have been ceramic coated :wink:
great, they are shiny and won't rust! :shock: radiant heat isn't entirely eliminated by a ceramic coating. it helps, but not like enclosing it and distributing that heat through a heat defusing fiber.
CRAMBURY RS
Postby RichardK » Fri 16.10.2009, 19:29
Hi Guys,
Just back from a week's vacation in the Tankwa Karoo National Park with the family :banana: Peace and tranquility.
I had barely time to post the pictures before I left. I started up and ran until the fans came on and tested while still on the stands. The oil smoke was a bit disconcerting but nothing fell off and it all looked fine up to 5500RPM.
Anyway this evening I got the car off the stands and ran it round the block a few times to get some confidence in my handiwork and get the computer learning the new engine set up.
THanks Marie for the feedback on the bolt - I'll swap it over. Monty I'm running stock injectors with the V5 switcher and it's running fine, Boost is controlled at 0.6 or 0.9 as per the program being used. It does need a really good run - hopefully tomorrow or Sunday and then I can report back properly.
Now I'm keen to get those injectors.
Rich
RichardK
Postby lotusgirlmarie » Fri 16.10.2009, 21:36
Awesome!!!
For the record, all my DP's are ceramic coated stainless steel. Rust wil never be an issue.
lotusgirlmarie
Goddess
Postby CRAMBURY RS » Mon 19.10.2009, 06:02
lotusgirlmarie wrote:Awesome!!!
and that's why you ROCK!
in the case someone does wrap their pipe, please DO NOT over wrap, it can cause damage over time by making the steel weak and brittle. try and keep the over lap to a half inch.
CRAMBURY RS
Postby a5gcd » Wed 21.10.2009, 14:53
[quote="RichardK]
Fantastic!![/quote]
Hi Richard
Did they reopen it just so you could test the Elan??
28 Rand is more like £2.80 now but well worth it.
Enjoy!! Geoff
a5gcd
Postby Dico » Sun 25.10.2009, 19:32
Install due any time now. 1) is sealant required alongside the gaskets, and 2) is copperslip recommended for nuts/bolts.
Thanks in advance. Brum Brum.
Postby RichardK » Sun 25.10.2009, 19:47
Dico, send me your email address and i will email a doc file with a collection of tips and instructions from Marie gathered from the forum - save you hunting.
RichardK
Postby Dico » Sun 25.10.2009, 19:57
Cheers Richard. On its way... :-)
Postby Monty » Sun 25.10.2009, 22:03
Ok, i`ll soon be starting to fit Dico`s Turbo upgrade for him (his Blue Beast is already on my drive :twisted: )
Dico`s manifold came with the adaptor plate already fitted as these where Jet hot coated but i can`t tell if a gasket was used as there is no gasket for it in the kit, so do i need to remove the adaptor plate from the manifold and seal it? (maybe only Marie knows the answer to that one :? )
Postby RichardK » Sun 25.10.2009, 22:26
I wondered that too - As per Marie's previous post - copper seal between the manifold and the adapter plate, the supplied gasket between the adapter plater and turbo..... :)
You do need to take off the adapter plate from the manifold - it isn't torqued up and there is no copper seal ( at least that's how mine came !) I had the full ceramic treatment too.....it's great stuff.
Monty - it's in my mutterings I collected and sent to Dico......did he press the send button on his email??
Good Luck
R
RichardK
Users browsing this forum: Bing [Bot] and 2 guests
