PAS Hissing
PAS Hissing
Postby Denny » Wed 02.09.2009, 15:13
Hissing noise from the PAS can be heard inside car when turning the steering wheel and it doesn't have to be full lock. Is this simply fix such as a fluid change or is it something else? There are no fluid leaks and the PAS seems to be working OK.
Denny
Re: PAS Hissing
Postby MattDon » Wed 02.09.2009, 15:15
its quite normal at low speed, bloody annoying though. If there is a "fix" i dont know about it.
please use email for contact
MattDon
Re: PAS Hissing
Postby texas2201 » Wed 02.09.2009, 15:54
Agree the hissing snake under the dash seems to be a common issue ..........
Re: PAS Hissing
Postby saska » Wed 02.09.2009, 16:30
Denny wrote:Hissing noise from the PAS can be heard inside car when turning the steering wheel and it doesn't have to be full lock. Is this simply fix such as a fluid change or is it something else? There are no fluid leaks and the PAS seems to be working OK.
The SE has always done this and changing the PAS fluid didn't change it at all.
The S2 has never done it but apparently Lotus revalved the S2 rack and this may be part of their reason.
Tony
adw (at) saska.co.uk
saska
Re: PAS Hissing
Postby Marcus_uk » Wed 02.09.2009, 16:41
saska wrote:The SE has always done this and changing the PAS fluid didn't change it at all.
My S2 has always done this...
Medina Green S2 #165 - Currently for sale :-(
Marcus_uk
Re: PAS Hissing
Postby Denny » Wed 02.09.2009, 16:42
Thanks guys. My mind is at rest.
Denny
Re: PAS Hissing
Postby keithlard » Wed 02.09.2009, 16:57
I call it 'the nest of snakes', and it's one of the many charming and individual features of the Elan, along with the glove box that doesn't shut...
If it is hissing particularly loudly, I tell my passenger: "The snakes are angry today!".
1991 200Tdi Defender 90
1991 Lotus Elan SE
keithlard
For what it's worth...
Postby tigerdog » Wed 02.09.2009, 23:22
My Fed Elan also hissed loudly. Because I also have a minor drip from the rack, I changed out the fluid for some "Valvoline High Mileage" PS fluid with stop-leak (yes, I know Lotus specify ATF and not PS fluid but the Valvoline claims compatabilty) Nearly two years later, PS still drips, though not as much, but hiss is greatly reduced compared to when I bought the car.
Re: PAS Hissing
Postby Blue_Bullet » Tue 20.10.2009, 01:41
No I didn't just do a silent one! Its the car honest!
The answer is out there, It’s looking for you. And it will find you if you want it to!
Blue_Bullet
Re: PAS Hissing
Postby Marcus_uk » Tue 20.10.2009, 09:12
Until now... for some unknown reason it has stopped hissiing except (when i reach full lock). The only thing I have done is change the power steering fluid, but that was over 5000miles ago. I will dig out the bottle and find what fluid i used.
Marcus_uk
Re: PAS Hissing
Postby steve matthews » Thu 07.01.2010, 13:56
Old Fed. car never hissed except upon full turn.
New car you must turn up stereo. In process of changing fluid small bits at a time.
Elan ownership, may swap out pumps :?:
Steve :m100:
steve matthews
Re: PAS Hissing
Postby tigerdog » Sat 09.01.2010, 06:11
Mine quieted significantly with a change of fluid. I broke the rules and went with non-approved "high-mileage" fluid because my rack was already leaking and I had hopes for its ability to swell seals. Rack still leaks but the steering is a whole lot quieter.
Re: PAS Hissing
Postby Aoki Magic Pants » Fri 19.02.2010, 13:33
My S2 used to do this when I first bought it. After a couple of months it suddenly stopped for some reason - perhaps because I'm using the car more regularly than it had been used previously?
Aoki Magic Pants
Re: PAS Hissing
Postby chris.t » Fri 19.02.2010, 17:02
TADTS
Re: PAS Hissing
Postby VagueShot » Sat 20.02.2010, 11:09
Both of our Elans did this. The second has done it for eighteen years. I'll worry when it stops doing it.
James Miller
http://anonw.wordpress.com/tag/lotus-elan/ - Ramblings of an anonymous widower and sometimes his ever-faithful Lotus Elan.
VagueShot
Re: PAS Hissing
Postby rip » Sat 20.02.2010, 11:32
Once used to it, I find the noise quite comforting.
Re: PAS Hissing
Postby Silverghost » Thu 26.08.2010, 12:37
My S2 has always hissed. Except at the moment, it's doing it when accelerating in a straight line.
Any ideas why that should be?
Silverghost
Re: PAS Hissing
Postby Specky » Thu 26.08.2010, 12:56
When did you last change the oil?
Oil becomes hydroscopic after years of use and also breaks Down.
First thing I would do is change it,
the noise is generated by oil flow so you may have an internal leak. What does your steering feel like.
Replace the oil and see how you get on.
Return to Chassis & Steering
