Thermostat housing
Thermostat housing
Postby hart17 » Tue 27.10.2009, 12:29
i need housing part #a100e6348s mech cracked it while changing sensor cannot find one please help my 91 m100 turbo needs you
hart17
Re: thermostate housing
Postby Ade » Tue 27.10.2009, 15:42
Hi,
There is a type of wire you can get to weld it just with a blow torch, I think you can get it from frost autos but not sure. I have seen this work it,s excellent.
Ade
Ade
Postby Specky » Tue 27.10.2009, 18:09
Postby ashm » Tue 27.10.2009, 18:41
Ade wrote:Hi,
Ade
Yep, you should be able to braze it if it's a reasonably clean crack with not too many bits. Find a local welding/brazing shop and ask their advice.
I can't remember if that part's alloy or ferrous? Despite a common belief that it's impossible, most cast iron can be welded too. But it's a very careful and specialist job there are cast iron welding specialists out there. I had an 80 year old grey iron lathe bed repaired by a company in Surrey recently, they did a great welding job on it with no measurable distortion.
Adam
ashm
Postby Specky » Tue 27.10.2009, 21:09
The housing is alloy on the N/A if that helps...
Return to Heating and Cooling
