cutlea01 wrote:As far as I can work out, the motor stalls when the window is fully up or down? The cables can't move any further, and as there's no clutch or switch it simply stalls, I think. My L/H motor would make a horrible clunk, clunk, clunk noise when the window was fully up (and sometimes befor it had got fully up), taking it apart it appeared the cogs were worn and slipping, so I replaced it with a new modified Renault item, and it now seems fine (well, alot better anyway).
scottswatches wrote:ok, door apart and window motor dismantled
the white spool in the middle is the one that makes the clunk clunk noise - it moves up and down. i'm going to try the washer/longer bolt option on the wiki but if anyone has any imput all is welcome
Specky wrote:What state are the White and black (rubber) drive blocks in.
It sounds to me as though not everything is located quite right under the drum
Alan_C wrote:... Then remove the cables from the white plastic slider on both the old and new units (you are going to reuse your old slider and rail).
Users browsing this forum: Google [Bot] and 2 guests
