gear cables
Drivetrain problems
gear cables
Postby richone » Tue 23.02.2010, 13:19
Is there a way to adjust the gear cables as i have a lot of travel as in the gear knob hits the dash and the hand brake .
with thanks richard
richone
Re: gear cables
Postby Specky » Tue 23.02.2010, 14:07
That sounds about right for a really worn set of cables, I take it you can still get all gears?
Re: gear cables
Postby rip » Tue 23.02.2010, 15:06
Not sure about the SE/NA cables. These apparently have a plastic fitting.
S2 & AB cables have adjustment on the bracket which sits on the back of the gearbox casing, but from what I have seen, these should move the centre position left/right/forward/back. The distance of each gear from the centre position should remain constant.
A shortshift kit would help matters. It makes a massive improvement to the feel of the whole car. The only drawback is that this places more stress on the cables. (work = force x distance: work remains constant & if distance is reduced, force must increase) S2 & AB cables have a metal fitting.
I highly recommend a shortshift kit &, if you are a bit nervous of your cables, a set of S2 or AB cables to go with them.
Re: gear cables
Postby richone » Tue 23.02.2010, 18:33
hi and thank you yes i can still get it in gear ok but where can i get the shortshift kit .
with thanks richard
richone
Re: gear cables
Postby BFG in the BRG » Tue 23.02.2010, 18:52
Here Shortshift group buy I can't reccomend a Dave Short-shift enough.
:mrgreen:
Alas soon to be Elan-less
BFG in the BRG
Re: gear cables
Postby HJ2 » Tue 23.02.2010, 19:21
Check out my tread as well, perhaps the crimps have worked loose. Repair is cheap, as long as it's S2 cables...
viewtopic.php?f=37&t=14821
Re: gear cables
Postby BFG in the BRG » Wed 24.02.2010, 10:33
Oh Oh,
while I think on I have a set of used SE cables after I fitted a shortshift kit and replaced the cables with AB Racing ones. After getting to the point of no return I founf the cables to be in very good nick :roll: so I fitted the AB's anyway.
If you want them make me an offer - say £40 plus delivery - I would point out however that if fitting a shortshift kit it is recomended by several people on this forum that you replace the cables with AB's which are stronger and all metal - the theory being that the shortshift kit puts extra load on the cables and they may snap - personally I don't necessarily agree - I think it depends on how you drive - if you are tracking then you are more likley to snatch gears and snap the cable - for normal use I don't believe it would be a problem - but there will be many who disagree - so I fitted AB's anyway - and found them to be a little stiff so that the gear stick didn't return to centre on its own - but it is getting better with use. By the way - fitting new gear cables is a bit of a pig of a job
AB's are available from Will B on this forum - AB also do a shortshift kit - (again from Will B) - which is a bit more complicated in it's operation and therefore more expensive - however IIRC it is also adjustable so you can adjust how much stick travel you want to change gear - personally I like Daves - simple to fit and works like a dream and cheaper - I could never see me changing settings besides ......I like simple.
BFG in the BRG
Re: gear cables
Postby Specky » Wed 24.02.2010, 10:40
A bit more information.... Clicky
Re: gear cables
Postby muley » Wed 24.02.2010, 11:15
After the bush debacle I'm not sure WillB is in cahoots with AB any more
Re: gear cables
Postby richone » Wed 24.02.2010, 11:53
hi how do i get hold of dave for a price for a shortshift kit and cables
ta richard
richone
Re: gear cables
Postby rip » Wed 24.02.2010, 14:32
richone wrote:hi how do i get hold of dave for a price for a shortshift kit and cables
ta richard
For the shortshift kit, add your name to the list on this thread. A PM to DeeAitch would be worthwhile too.
Dave does not make the cables though. You would have to get Lotus or AB ones. Lotus ones are very expensive though
BFG in the BRG wrote:I fitted AB's anyway - and found them to be a little stiff so that the gear stick didn't return to centre on its own - but it is getting better with use.
Monty found the reason for this: The bush fits too tightly on the spigot at the transmission end therefore resists any movement. 5 minutes with a needle file (once you get to it :( ) improves this greatly.
Re: gear cables
Postby steve matthews » Thu 25.02.2010, 01:24
You can also contact A.B. direct they are distributing
Short shifters and cables as I have just received a set.
Steve
steve matthews
Re: gear cables
Postby BFG in the BRG » Fri 26.02.2010, 16:08
But hopefully straightforward if done whilst replacing coolant pipes with Samco's :-D
and thus the Project creep began :banana:
BFG in the BRG
