Hood Tension Cables
Hood Tension Cables
Postby enndee » Sun 28.03.2010, 09:46
On the front end of the hood, the tension cables have a crimped fitting like a car electrics crimp tab, which is pop rivetted to the frame. :shock: One of mine has corroded and come away so the hood on that side is now loose and flappy!!!! :( Is it possible to replace the fitting or is it a cable replacement? Where can I get a replacement cable?
enndee
Re: Hood Tension Cables
Postby whippit » Sun 28.03.2010, 11:57
its a bugger to fix, i think you have to peel the fabric of the front frame back to get to it,
its on my todo list, all i did make sure the front crimped bit is not rubbing on the hood,
there's enough play in the cable at the rear to re crimp,
i didn't like the idea of peeling the fabric, think i needs a stainless crimp and rivet if its going to last,
whippit
Postby enndee » Sat 03.04.2010, 13:18
Thanks for the reply.
Have not been able to source any stainless steel crimp tabs so far. Does anyone have any experience of this problem? I have the normal electrical crimping pliers but considering the tension the hood is under, I doubt that they would exert enough pressure to stop the tag pulling off.
The car is not daily transport and I rarely use it with the hood up anyway, so it's not a massive problem but I do want to fix it. HELP please!!!!
enndee
Postby bobbrown » Sat 03.04.2010, 15:18
enndee, have you tried Trim Technology as they made them in the first place so may have the parts you need
Pacific Blue N/A
bobbrown
Postby enndee » Sun 04.04.2010, 12:49
Thanks Bob, can always rely on you to have the answer! 8)
enndee
