I've always had a slight coolant leak - nothing serious, just a few drops on the garage floor after a drive. Never tracked it down, but it has not been a problem as long as I top up the tank every few months. The car has been standing over winter and I fired it up again last weekend. Did all the usual checks, charged the battery and it started straight away, which made me happy! Took it for a gentle spin, then a more aggressive spin, then down to control technique (MOT to you), where it passed with flying colours. That was Tuesday.
Lovely morning today, so I thought I'd take it to work. I noticed that there was a little more liquid on the garage floor than usual, so checked the coolant tank again. It was low, but not much - maybe 1cm down from nominal. I opened the filler tank, and there was a big vacuum noise from the tank (like air was being drawn INTO the tank) and at the same time a big spluttery pop from the other side of the engine bay, somewhere near the turbo, or maybe the left hand side of the radiator. This is approximately above where the drops of coolant appear on the garage floor. Also noticed there is a small amount of white deposit around the coolant tank filler cap.
No time to investigate, so I decided not to drive it to work, a bit worried. What could cause this? The engine was totally cold. There cannot be any major leakage to the coolant system as there was obviously a good vacuum seal on the tank. Has a seal blown out or something? How can I proceed to check what it going on? I did notice that the temperature gauge never went up very far on Tuesday, but I put that down to the cold weather. The heater was working fine.
Any ideas much appreciated.
Roland
