by Gareth » Tue 13.04.2010, 11:52
Can anyone advise me how to remiove the 2 Speaker Pods behind the seats?
Thanks in anticipation
Gareth
Gareth
by Ade » Tue 13.04.2010, 12:46
Hi,
just unscrew the speaker grill and remove speaker, then gently pull the panel by the center tunnel to release a plastic push in stud.
Ade
by Monty » Tue 13.04.2010, 14:40
there should be a small hole on the top close to the edge nearest the door as there is a bracket there, you`ll need a longish posi screwdriver
- Chunder King!
by TheBard » Tue 13.04.2010, 16:35
As stated above, removal of the whole unit is fairly simple, just watch for the
Factory Installed Mouse
You can fit larger speakers if you can squeeze them into the housing and mount from behind the metal frame (avoiding the cone clashing with the circular opening).
TheBard
by DaveB » Tue 13.04.2010, 16:58
Monty wrote:there should be a small hole on the top close to the edge nearest the door as there is a bracket there, you`ll need a longish posi screwdriver
Really ?? Mine doesn't...
... I have a late SE... Maybe different ??
Time taken to post a picture on this forum - down to 35 minutes...
DaveB
by Ade » Tue 13.04.2010, 19:35
Mine hasn,t either
Ade
by Gareth » Tue 13.04.2010, 19:49
Thanks all!
Did it!
No Mouse : No Hole
Gareth
Gareth
by Monty » Tue 13.04.2010, 20:54
DaveB wrote:Monty wrote:there should be a small hole on the top close to the edge nearest the door as there is a bracket there, you`ll need a longish posi screwdriver
Oh right, maybe mades been modified as they do have aftermarket rear speakers in them.
when i get chance i`ll take a photo of the bracket which is on the back off the cover.
BTW i didn`t even realise that the stock speaker bracket was attach to the tub area
- Chunder King!
Return to Interior
