What happened when you tried without the Thermostat?
Maybe do an Elan Scan to make sure the temp readings are correct
Are you getting alot of bubbles/pressure in the coolant tank? Might be worth doing a block test to make sure that there`s no combustion fumes getting in to the coolant.
Andy_J wrote:Having tested it with an undertray fitted, that does seem to be the case, I am a bit surprised how much of a difference it makes, as I have run non-aircon elans without the undertray and they seem to cool properly
Andy_J wrote:Hi Pecks,
My problem turned out to be a blocked radiator core, the bottom half of the radiator was blocked. At high speed ther was enogh air being forced thrpough the top of the radiator to cool the car.
Tested it by filling it with boiling water. I fixed it myself by pulling the end taking off the radiator and putting a strip of plastic sown the core to clear it. It is a bit risky as you could end up with a bad seal on the end tanks (so i dont recomend doing this unless you are sure your radiator is the problem). I also removed my water pump to check it, but it was fine in my case
Have you checked you thermostat any air locks, etc in the system. I would suggest you check your radiator is getting hot all the way across, before you check remove water pump.
Users browsing this forum: Apple [Bot] and 2 guests
