ALL ELANS ON PISTONHEADS.
Elans for sale in the UK.
Discussion of prices of Elans advertised for sale on LEC is prohibited in open forum, private discussion is perfectly acceptable. A separate area for discussion of prices of Elans not advertised on LEC and market value generally is available in the 'Elan Buying Help section' of the 'For Sale' area.
Re: ALL ELANS ON PISTONHEADS.
Postby rip » Tue 03.08.2010, 15:09
Macachees wrote:Also, does anyone know anything about the BRG one?
Drove my first on Friday and it was fun! It was NA, what are the differences am I going to see/feel when I drive a Turbo?
A surge of power at about 2800 rpm :-D At lower revs it is slightly less powerful than an NA.
Don't accelerate while turning until you get used to the turbo. Once you do get used to it, accelerating away from a roundabout changes from frightening to fun. :D
The (notoriously inaccurate) boost gauge is where the clock was in a NA. You should feel the turbo when the needle hits 0.5bar. The clock in a turbo is hidden behind the indicator stalk & gone digital. You can only see it while indicating :poke:
Colour coded mirrors & PAS are both standard on a turbo. The turbo has a lower red line & has a slightly higher final drive. A turbo also acts as a silencer, so won't be as loud as an NA.
Postby nhaynes » Sun 12.09.2010, 09:21
I dragged my family kicking and screaming to Devon yesterday (no mean feet from London as it was a 9 hour round trip) to see this example on Piston Heads:
http://www.pistonheads.com/sales/1996443.htm
J950GMR
I was a little amazed before I travelled as it was advertised as only having 40,000 miles. The sceptic I've now become after viewing so many poor Elan examples, had me thinking it must be clocked but there was a strange good feeling I had about this one and the guy who was selling it, after my numerous conversations with him.
One we found the tiny North Devon village nestling in a valley, I finally got to see the Elan and what a fine example it was too. It has original unfaded Calypso Red paint work, a few tiny stone chips and the odd small scatch but what do you expect for a 19 year old car. The whole engine was immaculate and underneath was simply amazing. I wonder if this car has ever been driven in the winter or wet weather! The Prongeron was untouched and the "do not touch" sicker looked just like the day it left Hethel. Needless to say I had no worries with track rod arms or front/rear wishbones. The brake lines were also in very good condition. The owner admitted to recently wax oiling the underside which is why it felt a bit sticky. There were new pads and disks on the front and the rears were hardly worn, though later when I took the Elan out, I found the brales were terrible. It may require a bit of tweeking or it may just be that they haven't bedded in yet. Either way, I can handle fixing brake pads, disks or calipers. Inside the Elan was immaculate, I've never seen such good quality SE leather seats. There was a slight scuff on the drivers side upright but nothing a bit of boot polish won't sort out. The carpets and door trims were also unflawed. All the instrumentation works, the door mirrors and electric windows too. The electric windows even power up if they're left down when you lock the car with one of the two remote key fobs with the high grade alarm/imobiliser that's been fitted (I do worry about this if it goes wrong). The hood is in good condition, save for one small 20mm tear above the left side hinge mechanism. It's patched on the inside and I would give it some more attention to prevent it extending any further. The rear windown is clear so the roof will last a while but will need attention to get the car absolutely mint. The alignment of the roof to the rear top edge of the passenger door is also a little off as it randomly sometime leaves a gap when the roof is up. On other occasions it seals well. The drivers side roof seals are pefect, the passenger side has one or two very small chuncks out of the seal but nothing bad. The A post seals are in very good condition. The passenger B post cover is present but has become detached at some point in its history so will need replacing. I know these are like rocking horse sh*t so I may need LEC's help to get a replacement set. This Elan has 2 x Ignition/door keys, 2 x alarm/imobiliser fobs, 2 x remote entry key fob, 1 x boot key, 0 x glove box key.
After I spent about an hour inspecting the car, we took it out. The present owner Graham had no problem letting me drive it and apart from the brakes wich I mentioned earlier it was a beautiful drive. The gear mechanism felt a tad stiff but they may just be that I had spent 5 hours in my new Mondeo. The engine was the quietest I've heard, very responsive both off and on turbo. The boost seemed better than what I recall of my old Elan. There was no drive train rattles of squeeks, no wheel bearing or gearbox whines. In fact the only thing I could hear when moving was the wind in my hair and a slight sqeek from my seat belt.
On returning back to the village I was already excited but was fearful that the paperwork might reveal some hidden flaws. Graham invite us all into his house, (my boisterous 7 year old as well) and I spent 30 mins looking thought his well documented paperwork. The first thing that impressed me was he'd put everyting in order. V5 Logbook, service book, MOT certifcates, all present and all in order. (This makes a buyers task so much easier to authenticate the cars genuine history). He then has another file which holds all the service receipts including most of the service job cards! I cross checked all the service stamps with the job cards and cross checked the servies mileages with the MOT milegaes and was delighted to discover that the 40,000 miles is genuine. A this point, I think a rather large smile came across my face!
So, we had one last look at the Elan again. I asked Graham to show me how that alarm works and I showed my wife the issue with the hood and warned her she may get wet if it rains! I gave Graham a deposit and said I'll collect the car next week with the balance in cash. I left Devon a very excited Lotus Elan owner again!
I do have lots more pictures that the owner sent me other than the one on Piston Heads. I will also be using the Forum to sort out the few minor issues I'd like to fix. I also hope to take part in the next meet if my knee has recovered.
A few items that I'd appreciate feedback on:
1. How/where can I get duplicate boot key?
2. How/where can I get replacement glove box keys (none present with the car)
3. How/where can I get B post covers.
4. How/where can I get a replacement hood (I estimate £800 for this but will hold off for a while)
5. Does anyone know how to adjust the hood mechanism to mate with the door seals better (I mention the issue in the text above)
6. Does anyone have any stiff gear lever symptoms and know root cause?
7. Does anyone have any poor front brake performance, if so, what actions have you taken?
Thanks,
Neil.
Thanks,
Neil.
nhaynes
Postby Jackonicko » Sun 12.09.2010, 10:24
Congratulations, Neil, and welcome back.
There's a locksmith in Cowley who had stock of the right blank quite recently. I got a GM 6 (H). They had others. I think it was Bma Varsity Ltd at 15 Oxford Road, Cowley, Oxford, OX4 2EN, 01865 714000.
More problematic. Easier to replace the lock from a scrap Vauxhall.
South West Lotus or SJs make replacements.
4. How/where can I get a replacement hood (I estimate £800 for this but will hold off for a while).
Keep an eye on the cars being broken, or bite the bullet and have one made. See:
viewtopic.php?f=30&t=11556&p=145060&hilit=hood+trimmer#p145060
I did for thousands of miles after AB cables went in. Routeing is problematic.
Anyone with stock brakes, I suspect. After poncing about with grooved and dimpled and different pads, I had Hi Specs fitted. Bang! problem gone.
Jackonicko
Postby Specky » Sun 12.09.2010, 10:55
Duplicate boot keys....
On the side of your existing key there should be a letter... (take a note of that bad boy)
Send a PM to Muley
he'll sort you out with a blank to take to your locksmith... hope that helps
I believe the key blanks are free.... just a small donation to the LEC via Geoff.
Postby nhaynes » Sun 12.09.2010, 11:01
Thanks Jackonicko and Specky for your responses to my post. I guess you'll be hearing much more from me now!
Maybe a little premature as I don't have her yet. How do I get my Elan onto the SE Register?
Thanks,
Neil.
Thanks,
Neil.
nhaynes
Postby The Ref » Mon 13.09.2010, 22:15
Specky wrote:Duplicate boot keys....
Send a PM to Muley
thanks to me :-D
There are 3 types of people in the world. Those that can add up and those that can't
The Ref
Location: The "pools" HUFC must win a game some day soon
Postby tweetdriver63 » Mon 13.09.2010, 23:13
nhaynes wrote:7. Does anyone have any poor front brake performance, if so, what actions have you taken?
Almost anybody who still has stock brakes. I've read of a few who are happy with the stock after having the calipers completely overhauled. Personally, I'm about to install the Astra upgrade bobbrown came up with, just like rip has on his car. Astra calipers, subaru discs (294mm vs our 255mm), and a minimal amount of adapting hardware for the caliper brackets. I'm just waiting for Bob to send me the bolts, spacers and hub-centric rings he's made up for me. That whole kit will have cost me well under $300 US by the time it's on.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby gov » Tue 14.09.2010, 12:30
nhaynes wrote:Thanks Jackonicko and Specky for your responses to my post. I guess you'll be hearing much more from me now!
Thanks,
Neil.
Really pleased for you Neil - and the right colour!! A good car is always worth waiting for !
Tony
gov
Postby Macachees » Mon 04.10.2010, 18:39
Sorry to just keep posting entries like this but until I get one I can't really contribute anything more!
Does anyone know this car? Silver SE Reg G951 NNG I would be interested to know if it's been looked at by anyone here?
http://www.pistonheads.com/sales/2084031.htm
Macachees
Postby GeoffSmith » Mon 04.10.2010, 19:31
Macachees wrote:Sorry to just keep posting entries like this....
Don't apologise. We're here to help if we can. Unfortunately, I can't.
Postby Macachees » Thu 14.10.2010, 18:54
Macachees wrote:Sorry to just keep posting entries like this but until I get one I can't really contribute anything more!
Hi, I'm still interested in this car but hoping someone here already knows it before I make a trek up to Derbyshire from Kent! Any info is welcome.
Lyle
Macachees
Postby theelanman » Thu 14.10.2010, 19:45
can you ask the seller if they live in buxton.......
look s familiar.........if hes in buxton then I could go and have a look at it for you
cheers
G
Postby theelanman » Thu 14.10.2010, 19:54
i also seem to remember it being on piston heads a few months ago......
Postby Macachees » Thu 14.10.2010, 21:41
Very kind of you, thanks. I've emailed him and will let you know if he's in Buxton - fingers crossed!
Macachees
Postby theelanman » Sat 16.10.2010, 19:22
sorry......I should have thought.....brain wasnt in gear
just looked at the phone number......yes hes in buxton......our std code :)
Postby firetrap » Sun 17.10.2010, 15:46
Well here is my elan, finally had to bite the bullet and let her go! Absolutely gutted :cry:
http://pistonheads.co.uk/sales/2173242.htm
Any questions please drop me a message.
Im based just outside of Winchester in Hampshire.
I have just replaced the rear disks/pads, the only modification was on the car when i bought it and that is uprated front caliper disks.
firetrap
Postby TomE » Thu 11.11.2010, 23:53
I think this one has only gone on sale today but apologies if it's a re-post. Only 10,000 miles for a 1990 car - the lowest mileage one I've ever seen:
www.pistonheads.co.uk/sales/1850348.htm
TomE
Postby johnj » Fri 19.11.2010, 21:28
Hi this seems to be a very interesting car
johnj
Postby clemo » Fri 19.11.2010, 22:12
thats the one...... it really is the one to have...
clemo
Postby Specky » Fri 19.11.2010, 22:22
I've tracked it for a while....
Clicky
Return to UK Elans - For Sale
