Post your cries for help about using this forum. Please do not use this section for Elan-related problems.
by Specky » Wed 25.08.2010, 15:21
When you view this picture what do you see?
Half a gearbox or a full gearbox?
The uber mechanical geeks will see two gearboxs, but the above question is the one that counts.
You should see a full gearbox.
by RayD » Wed 25.08.2010, 16:29
RayD
- Forum Member
by Specky » Wed 25.08.2010, 18:06
1. Specky 1/2 Picture with Safari iPhone
2. Monty 1/2 Picture with
3. Ray 1/2 Picture with
4.Rip 1/2 Picture with Firefox
Does anyone know how to resolve it?
by dapinky » Wed 25.08.2010, 18:06
I get the full pic on Firefox, but when i have a 'sidebar' open (eg Bookmarks), then it cuts the pic down to what Ray indicates with the red line, with no option to scroll accross to the bit that was required - so I can see the potential problem with the original posting......
No prob on work PC with IE8 - half the pic, but with an option to scroll accross.
- LEC Administrator
by maz_r » Wed 25.08.2010, 18:22
Easiest fix is to ask the powers that be (is it Al?) change the bulletin board code to add a style to the posted images to force it to (say) 75% width.
The image will then resize to fit into the size of the browser window (and dynamically change when you resize the window).
- Code: Select all
<img style="width:75%" src="http://i615.photobucket.com/albums/tt234/Elan_SE/100_1221.jpg" />
Try it yourself by saving the line above in a text file with an 'htm' extension and then opening it with a browser.
Martin.
maz_r
- Binary Bodger
by theelanman » Thu 26.08.2010, 13:46
I get the whole thing.................
by RayD » Thu 26.08.2010, 14:40
Specky wrote:1. Specky 1/2 Picture with Safari iPhone
3. Ray 1/2 Picture with Firefox Edited.
... while I'm here ... if I post a picture bigger than about 550 pixels wide it shows on the LEC screen like so
and needs opening.
Other people seem to be able to post pictures that almost fill the screen, but are allready opened.
Jon for instance with the
magazine shots ... 800 wide
Tis a mystery
Ray
RayD
- Forum Member
by maz_r » Thu 26.08.2010, 17:35
Hi Ray,
If you upload your pictures using the 'upload attachment' function when posting a message (and then do the 'display inline' thingy), you are limited by the size of the file and the max width & height.
If you upload the picture elsewhere (like photobucket) and then just put in an image tag with URL that points to your photobucket picture, it displays the full picture at whatever size it is on photobucket.
Hope that makes sense.
Martin.
maz_r
- Binary Bodger
by RayD » Thu 26.08.2010, 17:47
Thank you Martin,
Another mystery solved.
Ray
RayD
- Forum Member
by Specky » Thu 26.08.2010, 20:35
Don't forget Photobucket is in theory a free hosting sight. We (The LEC) pay for our little chunk of cyberspace, so our hand is forced to limit the size of photographs, avatars etc... due to storage space. As Geoff would say "all donations welcome" and a small deposit his way never goes a miss.
Just keeping you in the picture...
by kenich » Thu 26.08.2010, 20:46
I get the same as most using firefo
Uploaded with
ImageShack.us
kenich
by Specky » Thu 26.08.2010, 21:46
I think it's due to the sreen size, if your wide screen full picture, square screen 3/4
So whar Maz-r says sorta makes sense
by muley » Fri 27.08.2010, 20:01
Whole thing on google chrome
Return to Forum (not Elan!) Questions/Problems
