What's this...
Share your pictures!
Re: What's this...
Postby inkitin » Tue 19.10.2010, 22:03
Andy_J wrote:Could it be 'Bracket,engine steady (cast), RH Mount' ?
You're so, so close with that Andy!
If you'd left out the "RH Mount" bit, I might have thought you'd got it.
There is one particular word I'm looking for.
91 SE Calypso Red
inkitin
Re: What's this...
Postby Monty » Tue 19.10.2010, 22:42
Thats easy, gearbox (middle) mounting bracket :-D
Re: What's this...
Postby inkitin » Tue 19.10.2010, 23:04
Monty wrote:Thats easy, gearbox (middle) mounting bracket :-D
I cannot believe that Monty! You've managed to identify the correct part without using one single word from the description I have. :shock:
Well done Sir.
Just in case anybody's confused, which I certainly am :-D , the part No is B100A0570F and the part description is "Extension Plate, (Cast), engine rear steady arm."
The baton passes to you now Monty and here it is:
Well done to Andy as well, you were so close. :clap:
91 SE Calypso Red
inkitin
Re: What's this...
Postby Monty » Wed 20.10.2010, 17:25
Re: What's this...
Postby Specky » Wed 20.10.2010, 17:38
Would that be two items Monty.... Part of one in the fore ground and one in the aft not requiring ident?
Can't guess thou, leving the country in a few hours....
Re: What's this...
Postby esprit888 » Wed 20.10.2010, 18:08
Looks like a trick shot? one of the items is the head intake cam plug ?
esprit888
Re: What's this...
Postby Monty » Wed 20.10.2010, 20:09
Specky wrote:Would that be two items Monty.... Part of one in the fore ground and one in the aft not requiring ident?
It`s listed as one item :?
esprit888 wrote:one of the items is the head intake cam plug ?
Nope,
Re: What's this...
Postby steve matthews » Wed 20.10.2010, 23:01
Thats one rusty Cas :-D
Steve -w- new lady
steve matthews
Re: What's this...
Postby Monty » Wed 20.10.2010, 23:10
steve matthews wrote:Thats one rusty Cas :-D
Steve -w- new lady
Well done Steve :wink:
Re: What's this...
Postby steve matthews » Thu 21.10.2010, 00:07
Whats this?Image
steve matthews
Re: What's this...
Postby Monty » Thu 21.10.2010, 20:21
Since yours is a Fed Elan just wondering if that is the plastic try/cover in the hood storage area ie covering the battery etc :? if it is then ours is different :lol:
Re: What's this...
Postby Dave Eds » Thu 21.10.2010, 20:30
close Murph - but metinks it's over the other side of the roof stowage area, and is probably vertical, and has the fuel neck cut out! :)
Re: What's this...
Postby steve matthews » Thu 21.10.2010, 21:50
Monty you are correct.
Sorry for the delay in response it seems that pond is in the way.
Steve
steve matthews
Re: What's this...
Postby Monty » Thu 21.10.2010, 23:21
Re: What's this...
Postby bobbrown » Fri 22.10.2010, 08:13
spider, steering wheel to boss
Bob
Pacific Blue N/A
bobbrown
Re: What's this...
Postby Monty » Fri 22.10.2010, 11:20
bobbrown wrote:spider, steering wheel to boss
Bob
Now you`ve done it Bob, your turn :lol:
Re: What's this...
Postby bobbrown » Fri 22.10.2010, 13:04
Pacific Blue N/A
bobbrown
Re: What's this...
Postby Specky » Fri 22.10.2010, 16:23
I know what that is...
I'll wait to ask more questions though,if it takes a while I'll send a PM
Re: What's this...
Postby theelanman » Fri 22.10.2010, 17:13
i too know what that is.....well I know Ive got one on the window ledge.....just need to find out what its actually called and its part number........
however Im off to the pub very soon......
might be tomorrow :)
Re: What's this...
Postby dapinky » Fri 22.10.2010, 17:24
I know what it is (and i've got 8 of 'em!) - but won't play 'cos i aint got the time to find any pics to put up!!!!!
Return to Picture Gallery
