euro steering wheel
euro steering wheel
Postby bratboy_y2k » Tue 02.11.2010, 06:22
does anybody know if the european steering wheel will replace the federal airbag wheel directly or is there messing around that has to happen?
bratboy_y2k
Re: euro steering wheel
Postby lotos » Tue 02.11.2010, 06:49
If you mean a non-airbag wheel, it's been done with some work:
viewtopic.php?f=39&t=13034&p=166217
viewtopic.php?f=39&t=11263&p=139415
If you mean an airbag wheel, we're working on a project to get a newer Elise airbag wheel in the Elan:
viewtopic.php?f=85&t=14783
lotos
Postby esprit888 » Tue 02.11.2010, 06:59
bratboy_y2k wrote:does anybody know if the european steering wheel will replace the federal airbag wheel directly or is there messing around that has to happen?
If you mean a non airbag wheel then the short answer is yes,I have had mine on for over a year now and it makes the world of difference. You will need to shave the tab off the bottom of the hub but thats it (and remove the bulb from the SIR light on the dash) The hub splines are identical, and they are also the same as the Esprit.
esprit888
Postby tigerdog » Tue 02.11.2010, 18:58
esprit888 wrote:If you mean a non airbag wheel then the short answer is yes,I have had mine on for over a year now and it makes the world of difference. You will need to shave the tab off the bottom of the hub but thats it (and remove the bulb from the SIR light on the dash) The hub splines are identical, and they are also the same as the Esprit.
Are you speaking of the stock Euro Elan wheel of the same vintage?
Postby bratboy_y2k » Wed 03.11.2010, 01:44
yep an elan se wheel. i dont want an elise wheel. happy with the uk wheel. so a little machining eh? were they all black?
bratboy_y2k
Postby esprit888 » Wed 03.11.2010, 06:46
Yes, i'll post some pics when i get my other PC back (i may need a poke to remember :-D )
esprit888
Postby esprit888 » Wed 03.11.2010, 06:50
bratboy_y2k wrote:yep an elan se wheel. i dont want an elise wheel. happy with the uk wheel. so a little machining eh? were they all black?
I have one which is black, and i switch between another which is black with alcantra (sp) i believe this one was euro Elise?
esprit888
Postby esprit888 » Fri 05.11.2010, 04:59
This is the Euro one i have on at the moment, you can see the area that needs to be ground off (i believe its the cancel tab on the euro car?)
esprit888
Postby Specky » Fri 05.11.2010, 08:09
The SE steering wheel is more of a really really dark brown.
As another option you could use the N/A steering wheel. At first impression it looks identical, but it's plastic coated as oppossed to leather. It's such a close match to the SE wheel I don't think any Laymen would notice.
Here's the N/A wheel. (No grubby leather stitching, shrinkage or fading)
Postby tigerdog » Sun 07.11.2010, 22:03
Specky wrote:The SE steering wheel is more of a really really dark brown.
Are you sure the leather wheel is really dark brown? Or is it just 20 years of skin oils and dirt soaked into the leather??? Oh, and I suppose you've cornered the market on N/A wheels and are now offering them at a reasonable price, right? ;-)
Postby Specky » Sun 07.11.2010, 22:52
You could be right there...but you missed out a "really" :wink:
Blacks not a colour, it's a shade.....:smt110
The steering wheel is squirreled away for the project car...
Postby bratboy_y2k » Mon 08.11.2010, 21:35
esprit888 wrote:This is the Euro one i have on at the moment, you can see the area that needs to be ground off (i believe its the cancel tab on the euro car?)
there was a euro m100 with an alcantra wheel option?
bratboy_y2k
Postby esprit888 » Mon 08.11.2010, 21:47
This is the Euro elise wheel, i like it more than the euro M100 wheel i had on as its smaller (in the pic it looks huge but it feels like a go cart wheel) Whats a Euro m100 wheel worth to you? (as i have two :) )
esprit888
Postby bratboy_y2k » Thu 11.11.2010, 08:37
hey there i sent you email.
bratboy_y2k
Postby Elanlover » Sat 13.11.2010, 19:29
Specky wrote: Blacks not a colour, it's a shade.....:smt110
Technically, black is a lack of all colours with white being all colours combined.
Which is why white is the best colour for an Elan...............
Return to Interior
