by tomatcbl » Sun 07.11.2010, 00:48
Just getting used to my 'new to me' M100. With the soft top up, there is a gap of about 2-3 cm between the back of the soft top and the roof stowage lid all the way around. Is this normal - I suspect not? Is there any adjustment? Any suggestions? Thanks
__________________________________________________________________________________
Tom
1991 Yellow M100
Maryland
tomatcbl
- Tinkerer
by theelanman » Sun 07.11.2010, 01:32
no...not normal.....
it sound like your frame isnt locking in position.....
with the roof up...just check the diagonal stays which run from just behind/above your head which go down to the base of the rear of the hood are locking square rather than not locking and being 'kinked'
cheers
G
by tomatcbl » Sun 07.11.2010, 02:17
The diagonal stays are kinked. If I push them straight, they do push the back of the soft top flush with the roof stowage lid, but in so doing, they introduce a kink in the roof sides where the windows would meet the roof - and the diagonal stays will not stay straight - will take photos in morning. Thanks for suggestions.
Tom
1991 Yellow M100
Maryland
tomatcbl
- Tinkerer
by lotusgirlmarie » Sun 07.11.2010, 08:27
The trailing links should be bolted to the drop arms and have a second "cam" bolt to adjust tension. I have found that some owners remove the fixing bolts as to not allow the tops rear seal to rub on the stowage lid.
lotusgirlmarie
- Goddess
by tomatcbl » Sun 07.11.2010, 16:01
I have looked at the rear diagonal bars. One of the bolt housings is certainly eccentric and might act as a cam, but it is not touching anything that it could adjust. I have attached photos to help. On the first image - rear diagonal bars, you can see the gap at the bottom of the soft top. It is hard when you don't have another vehicle to which to compare. Thanks for advice
Tom
1991 Yellow M100
Maryland
tomatcbl
- Tinkerer
by lotusgirlmarie » Sun 07.11.2010, 17:24
There is a rather odd shaped bar above the window opening that locates the diagonal bar. It's most likely bent out of shape and therefore not pulling the diagonal taught enough. This is where you will need to look and finesse the bar into shape.
lotusgirlmarie
- Goddess
by tomatcbl » Sun 07.11.2010, 17:38
Thanks - does someone have a photo of the bar so that I know what I am looking to achieve?
Tom
1991 Yellow M100
Maryland
tomatcbl
- Tinkerer
by Specky » Sun 07.11.2010, 17:40
Yes, but Photobucket is down at the moment..
I'm waiting for it to come back up
by Specky » Sun 07.11.2010, 17:54
Here's one to start with....
Does that help fella...
by tomatcbl » Sun 07.11.2010, 19:59
magic - thanks for photos - will report back once I have a solution. Cheers
Tom
1991 Yellow M100
Maryland
tomatcbl
- Tinkerer
by texaselite » Tue 18.12.2012, 00:12
I am having the exact same issue as tomatcbl, the frame is not locking into position. How can I finesse the odd looking bar that runs across the top of the side window into shape to pull this tighter?
texaselite
by Nickydee » Tue 18.12.2012, 11:19
texaselite wrote:I am having the exact same issue as tomatcbl, the frame is not locking into position. How can I finesse the odd looking bar that runs across the top of the side window into shape to pull this tighter?
I tried "adjusting" or more accurately bending the "odd looking bar" without initially much success, I think this was because my bars were badly out of shape.
I then removed the bars from another car - a five minute job - and used them as a template. When I refitted mine one side was perfect and the other just need a slight adjustment but it was easy to work out was required.
First attempt a couple of hours with no success, second successful attempt with a template half an hour max.
by dapinky » Tue 18.12.2012, 16:00
Have a quick read through
this short thread for a couple of pics and hints
- LEC Administrator
by RayD » Wed 30.01.2013, 22:17
I made an observation today that might be useful at some point ...
If you hold the hood stowage lid fully open and put the roof back into the up position it doesn't reach it's normal landing position on the top of the screen ... mine's a quarter of an inch short, too far away for the clips to come into action.
It may be it is supposed to be precisely like this to ensure sufficient pressure on the stowage cover under normal conditions.
The roof also needs to be parallel to the screen in this position to make sure of even pressure across the back cover.
Ray
RayD
- Forum Member
by Rusty Wishbone » Thu 28.03.2013, 00:17
My hood seals nicely against most of the hood cover panel, but I do have a gap between the hood and the concave curved leading edge of the hood cover panel. I can stick my fingers through it. Is there a way of closing this gap?
Rusty Wishbone
by Rice crispy » Thu 28.03.2013, 12:14
Mines always been the same rusty
Rice crispy
by Rusty Wishbone » Mon 01.04.2013, 01:38
Thanks. It is as if the designers gave up trying to keep the water out when they got to this point.
Rusty Wishbone
by madbilly » Sun 21.04.2013, 14:50
I also wondered about this gap, but I don't think water comes in that way anyway, certainly not when stationary. You could test it by going for a drive in the rain and putting a piece of kitchen roll or tissue there and the see if it's wet when you stop.
madbilly
